2000 F-250 Crew Cab rattle? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-02-2003, 05:43 PM
mltdwn12 mltdwn12 is offline
mltdwn12 is starting off with a positive reputation.
I have a 2000 Crew Cab, at highway speeds there's an annoying rattle that sounds like it's coming from the upper back of the front door/window. I can't seem to isolate this, anyone else have this? It also occurs on the passanger side as well.
Old 02-02-2003, 06:13 PM
robmcin robmcin is offline
robmcin is starting off with a positive reputation.
Yes, We have it on our 350 also, not all the time but right up above and behind your head on the front door. Never found what it is and it never seems to happen under the same circumstances twice.
Rob
Old 02-02-2003, 06:58 PM
Yup, that's it.Truck rides real nice except for that annoying rattle
Old 02-02-2003, 07:44 PM
mbnv992 mbnv992 is offline
mbnv992 is starting off with a positive reputation.
I think that all us super duty owners has experienced a nosie at one time or another. I have a super cab, and it rattles all the time, evean more so when going over pot-holes/ large bumps.
Oh well, it IS a truck lol.
Old 02-03-2003, 10:05 AM
jamesg jamesg is offline
jamesg is starting off with a positive reputation.
Super Duty trucks are known to rattle in the crew cab or super cab configurations. You can adjust the door strikers and latch mechanisms. Do a search on rattles and you'll find out exactly how. There was a post on this subject not too long ago.
Jimmie
2003 F250SD XLT SC SB 4X4
Old 02-07-2003, 03:36 AM
wgm114 wgm114 is offline
wgm114 is starting off with a positive reputation.
Take a #41 Torx Head and loosen the strike plates. The black plates at bottom of door well. Bump them back with a hammer and re-tighten. Lube your gaskets around doors and prest.....no more rattle.
Old 02-07-2003, 05:02 PM
Ford X Four Ford X Four is offline
Ford X Four is starting off with a positive reputation.
Yeah, I too hear a rattle on the drive side door. Only because I thumping massive sounds. Then I turned it sounds off, it rattles, i'm curious but cannot seem to find it when driving. Sounds like it's coming from the panel, the switches for windows and mirrors. I dont know might be wrong.
1999 Superduty 4x4, V10
Old 02-07-2003, 11:02 PM
keithf's Avatar
keithf keithf is offline
keithf is starting off with a positive reputation.
On crewcabs, if it's only happening at high speed then it's the plastic plate between the 2 doors. The rear of your front door is a little further in than the front of your rear door. This causes the wind to "flap" the plastic plate. Put some tape over the gap and test drive it - if the high-speed noise is gone you found the problem. How to solve it....well that'll cost ya! Haha!
Old 02-08-2003, 08:36 PM
79CEEJAY's Avatar
79CEEJAY 79CEEJAY is offline
79CEEJAY is starting off with a positive reputation.
Try a little spray silicone first. If that does not work, tighten up the strikers. At first they look as if they won't move, but if you rap 'em firmly, they will move. Just make sure you don't losen them too much, or they will spring back to where they were. I outlined mine with a pencil first to make sure of how much I moved them. What I did learn was this.....the rattle is actually the gasket rubing on itself....you see it is a "tube" if you will, and the internal surfaces are rubbing each other. You can take the tube from the spray silicone and spray into the small "vent" holes on the gasket to get some lube inside the gasket if you want. But most likely, you just need to compress the gasket a little tighter by moving the door striker in a little bit.
I have to give credit to FortyFords, though because he gave me the encouragement to tackle the job of adjusting my doors without the pain of having some apprentice body man at the dealer mess them all up......so I believe I owe most credit to Forty for what I learned about this subject.
Old 02-09-2003, 11:14 AM
Kraut Kraut is offline
Kraut is starting off with a positive reputation.
Do what i did on my motorcycle.
Put on a LOUDER exhaust so you can't hear it anymore
Kraut
Old 02-09-2003, 02:23 PM
jetjock16 jetjock16 is offline
jetjock16 is starting off with a positive reputation.
you have to get the doors to close tighter by moving the stricker plate back, youll probably have to replace the bolts, ive explained the process many times, search door rattles, ive done it to all my doors and have instructed others on the same process, now we are all Rattle FREE!!
Jetjock16
Extended Cab door rattle sagmill 1999 to 2016 Super Duty 15 03-19-2013 02:47 PM
Crew cab rear door rattle fix? mizzitch 1999 to 2016 Super Duty 1 01-25-2013 03:32 PM
front end rattle davew250 1999 to 2016 Super Duty 7 03-26-2008 07:54 AM
Rattling sun roof RougeDoc 1999 to 2016 Super Duty 1 02-25-2008 10:52 AM
dash rattle cojab 1994.5 - 1997 7.3L Power Stroke Diesel 4 08-31-2006 07:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
