Rear Cargo Management System - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 05-19-2010, 12:43 AM
st381 st381 is offline
st381 is starting off with a positive reputation.
Does anyone know the part number or OEM description of the bracket that holds the shelf for the cargo management system on a 07 Ford Expy EL. The bracket is there but spins around and I am **** and want to replace with a new one. The plastic flanges that hold it in place are broken.
It is the driver's side bracket that either holds the shelf in a shelf position or as a cargo area divider. There is one on each side.
Thanks in advance,
st381
Old 05-20-2010, 12:40 AM
Does anyone have a parts diagram for the rear interior trim of a 07 Expy EL?
Old 05-20-2010, 12:28 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Which part of the rear interior? Hatch door, rear sides? PM me.
Old 05-20-2010, 01:23 PM
I don't know how to PM, sorry. I am looking for drivers side rear interior trim diagram or parts list so I can order a replacement Cargo Management Shelf bracket. Can't find the name of the plastic doohicky anywhere.
Old 05-20-2010, 01:30 PM
berry1234's Avatar
I only have a diagram of the passenger side for some reason. Best bet is to go to a dealer and have them pull up the schematic.
Old 05-20-2010, 11:08 PM
Well, I went to the dealership and even though the part I need is removable, it looks like I would have to order the entire driver's side rear trim for $390.00. I can live with the broken piece until I figure out how to self engineer a solution or find an Expy in the junkyard.
Old 05-21-2010, 11:53 AM
berry1234's Avatar
If you have all the broken pieces, JB Weld is your friend. A quick epoxy will work nice too.
Overhead storage mod - 2010 TC Paul Mourer Transit Connect 5 05-06-2016 09:02 PM
96 bronco cargo cover littlejohn6977 1978 - 1996 Big Bronco 13 07-16-2013 05:35 PM
Expedition EL Cargo Management System Brackets imnes 2007 - 2014 Expedition & Navigator 3 11-20-2012 09:31 PM
Musty A/C Smell st381 2007 - 2014 Expedition & Navigator 4 06-25-2010 02:31 PM
holes in the bed jda1961 2009 - 2014 F150 12 04-12-2009 03:29 AM
Tags
cargo, caro, duty, escape, f150, ford, install, lincoln, management, managemment, managment, rear, super, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
