Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-18-2010, 03:08 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Reactor Pump died.
Just for what it's worth, my reactor pump was a $19.99 special Clearwater Centrifugal pump (1/2 hp). It died after 615 gallons of Bio made. Found a 1 hp pump for $62.99 and will hopefully get more life out of it. Some of the oil that I got was rather thick, so I think it was just too much of a load on the pump. I am thinking that I need to tell that supplier that I just can't use his oil ...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 05-18-2010, 03:26 PM
Midwest Dually's Avatar
Midwest Dually Midwest Dually is offline
1994 Ford F-350
My Garage
Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.
Awesome! What kind of pump was it you found to replace the burn out?
__________________
- Chris -
1994 F-350 CC Dually : DRW 4x4 XLT, 97 7.3 DIT conversion, tuned, open pipe and modded!.
  #3 (permalink)
Old 05-18-2010, 04:18 PM
Rushmore X's Avatar
2003 Ford Excursion
Another Clearwater. This one is 1 hp instead of 1/2 hp. Would think the extra grunt would keep it from being overloaded like the other one. Input and discharge ports are the same size as the old one, so it should plug right in.
__________________
  #4 (permalink)
Old 05-19-2010, 02:50 AM
1994 Ford F-350
My Garage
Wow.. Ok, cool! I gotta check that out!
PS: I just caught that you said that in your orignal.. Long days!
__________________
- Chris -
  #5 (permalink)
Old 05-19-2010, 07:17 AM
kirkharrod's Avatar
kirkharrod kirkharrod is offline
Garage is empty, add now
kirkharrod is gaining momentum as a positive member of FTE.kirkharrod is gaining momentum as a positive member of FTE.
I have heard that the Northern Tool brand pump lasts longer than the Harbor Freight.
__________________
2002 F-250 Super Cab, 289,000 miles, 89,000 on WVO; Greasecar conversion, 20 plate heat exchanger, AIH delete-water injection in its place, DIY stock fuel bowl delete, 6637 air filter w/ Pete's cover, Straight Piped, GPR LED mod, CAT ELC, 203* thermostat, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, Aeroforce Interceptor scan gauge, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. No major grease related problems.
  #6 (permalink)
Old 05-19-2010, 04:01 PM
1994 Ford F-350
My Garage
I didnt even know that Harbor Frieght dealt in pumps, good to know if I need a back-up! LOL! Northern tool, I like their products in other areas, but I wish their pricing wasnt so high on some products.. I will have to check out the pricing they have for theirs!
__________________
- Chris -
  #7 (permalink)
Old 05-19-2010, 05:36 PM
Rushmore X's Avatar
2003 Ford Excursion
Looked for a 1 hp Northern tool pump but couldn't find one...
__________________
  #8 (permalink)
Old 05-23-2010, 09:27 AM
Rushmore X's Avatar
2003 Ford Excursion
Got it a day early, I'm back in the Bio again!
__________________
  #9 (permalink)
Old 05-23-2010, 01:47 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Crappy pumps are one reason why I went to mechanical mixing, and I use an air powered diaphragm pump to move the bio around.......
No sparks= no
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #10 (permalink)
Old 05-23-2010, 03:03 PM
FORD RANGER's Avatar
FORD RANGER FORD RANGER is offline
FORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud of
true don.....
__________________
jack, slackmaster #6
1996 ford ranger xlt extended cab,2wd,4.0L v6,5spd,3.08 gears, tornado intake spacer, msd ignition,sun super tach2, k&n air filter, nascar oil filter.
iowa chapter member
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
