Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-18-2010, 01:53 PM
BLACK 6's Avatar
BLACK 6 BLACK 6 is offline
Garage is empty, add now
BLACK 6 is starting off with a positive reputation.
7.3 starts then dies
My 7.3 (1989 F350) is having issues, I tried cussing at it, kicking the tires, screaming and calling it all kinds of dirty names to no avail. So the symptoms are:
Key on, wait for glow plug light to turn off.
Light turns off, crank the engine over.
Fires within a few seconds but then stumbles and dies like it is starving for fuel.
Turn key off, then on again wait for glow plug light to turn off.
Light turns off, crank the engine over, and over, and over, and over, and over.
Light turns off, hold go petal down, crank the engine over, and over, and over, and over, and over, White smoke starts coming out of tail pipe, still turning engine over, and over and over.
Engine fires and runs fine.
After leaving it at work for 8 hours it fires like it is supposed to, but next day or if left for more than 10 hours, see above.
And yes, it has fuel (the correct type too). There is no fuel on the ground so I dont think it is a leak.
Any ideas? It is in need of a water pump soon (that is one thing that is leaking) but other than that it is servicable. Help me before I go and get my gun to put myself out of it's misery.
__________________
88 F250 Extended 4x4 7.3l
89 F350 Crew Cab 4x4 7.3l
04 F350 Crew Cab 4x4 6.0l
"You will know me by the scars I bear.
You will know me by the hate I swear."-OTEP
  #2 (permalink)
Old 05-18-2010, 02:08 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is online now
hairyboxnoogle is gaining momentum as a positive member of FTE.
ranger_nog hairyboxnoogle
Sounds like theres air getting into the pressure lines... check into a return line kit would be all i can think of.
__________________
'92 F-250 XLT, Dads - Supercab, 4x4, ZF, 7.3 ATS 088. Mostly stock for the moment.
'79 F-350 Custom, Disassembled-Super Cab Flareside - Getting 250cc 4k-kit P-pump, compounds, and 9spd
  #3 (permalink)
Old 05-18-2010, 03:23 PM
lowridaz22 lowridaz22 is offline
lowridaz22 is starting off with a positive reputation.
I was having the EXACT same problem.
Now, I wait till the voltage guage stops clicking ( cycling through the plugs? ) then it fires up fine. If I try to start it before the clicking stops it'll stumble and have the same symptoms as Black's truck.
  #4 (permalink)
Old 05-18-2010, 04:12 PM
greywynd greywynd is offline
greywynd is starting off with a positive reputation.
Black, when it's sat long enough that it would do this, pop the fuel filter off and see if it is full to the top, or if it has drained down some. You may not have fuel leaking out, but you may have air leaking in, and letting the fuel drain back from the injectors and IP.
I suspect this is the major issue, and you will need to put a return line kit in it. (Generally called an injector installation kit at the parts places, with the copper washers only being used if you were to actually replace the injectors.)
Another thing to look for, if the rubber return lines between the injectors have the factory gray paint, they are original, and a good sign they should be replaced, along with the o-rings under the plastic caps.
__________________
2001 F250 Superduty, 6.8V10, 2WD, auto. The 'family' truck.
1991 F350 4x4 E40D, N/A 7.3 Diesel, SRW, Crewcab, now with Meyer plow.
1990(?) F350 4x4, E40D, N/A 7.3 Diesel, with Meyer poly plow, needs a body swap.
1991 F250 4x4, E40D, N/A 7.3 Diesel, 'the runaway'
1989 F350 2wd C6 N/A 7.3 Diesel Dually w/flatbed dump, retired with a broken frame rail.
1988 F250 4x4 C6 N/A 6.9 Diesel, parts truck
  #5 (permalink)
Old 05-18-2010, 07:13 PM
1994F2507.3L's Avatar
1994F2507.3L 1994F2507.3L is offline
1994 Ford F-250
1994F2507.3L is starting off with a positive reputation.
was having the same problem.... well still am actually lol my return line kit is sitting on the floor next to me....
another thing to do while doing the return line kit is replace the fuel filter with this one
WIX 33617 - Fuel/Water Separator 1994 Ford F-250 | O'Reilly Auto Parts
that factory one will leak and was also causing my fuel to get air in it
  #6 (permalink)
Old 05-18-2010, 09:04 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
The leaking return lines usually do not leak fuel out.
They let air leak in, breaking the vacuum that holds fuel up in the fuel system when the engine is not running.
So you start the engine on the fuel left in the IP, then suck in the air pocket from the fuel filter, and the engine runs out of fuel.
Now you have to crank the crap out of the starter, shortening the starter life considerably, to pump the air through the injection system before it has enough fuel to fire again.
When you only let it sit for a short amount of time, the air has not let all of the fuel drain back to the fuel tank, so the engine starts fine.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #7 (permalink)
Old 05-18-2010, 11:52 PM
tbone91 tbone91 is offline
tbone91 is starting off with a positive reputation.
Speaking of the starter, crank for a maximum of 20 seconds and then wait two minutes before trying again. Otherwise, you'll be changing the starter along with the return lines...at least that's what happened to me.
__________________
91 F350 dually crew cab, Rebuilt E40D + TC, ATS turbo, stock intake & exhaust
  #8 (permalink)
Old 05-19-2010, 12:22 AM
Brad Leroy's Avatar
Brad Leroy Brad Leroy is offline
1994 Ford F-250
Brad Leroy is starting off with a positive reputation.
I had the same problem. Check out http://www.ford-trucks.com/forums/94...fuel-pump.html for a possible solution.
Good luck!
  #9 (permalink)
Old 09-20-2012, 02:05 PM
Opossum Opossum is offline
1989 Ford F-350
Opossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to all
Black, what did this turn out to be?
Tags
1991, 1994, 69, 69l, 73, dies, diesel, ford, offexpidition, powerstroke, runs, shouts, starts, truck, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
