Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #1 (permalink)
Old 05-17-2010, 11:24 PM
blowhole's Avatar
blowhole blowhole is offline
Garage is empty, add now
blowhole is starting off with a positive reputation.
Installing Driving Lights - Wiring Question
Got a wiring question: Got 4 Hella's I am installing and am curious what wire I need to tap into for energizing the relay(s) so that the lights can come on with both the high and low beams??
Is it easiest to tap the wire just behind the headlight? If not, where is the best place to tap it?
For info purposes: I am installing two switches on the dash to control each set of 2. I am just using the Hella harness that came with the lights, nothing complicated.
Thanks in advance, and let me know of any best practices ya'll have found when doing similar mods.
__________________
blowhole
sold --> [ 2005 Excursion - Eddie Bauer - 6.0L PS ] : DieselSite Coolant Filter : Zoodad w/ Z-Plate : 4" MBRP TB Exhaust w/ 5" tip & No Cat : Thule Rack on stock rails : ISSPro Boost & Trans Temp & EGT : Fumoto Valve : Silverstar Lamps
  #2 (permalink)
Old 05-18-2010, 12:01 AM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
2000 Ford F-250
My Garage
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
I just installed two Hellas, but I ran my relay off the high beam with no switch so when I hit the high beams the Hellas come on at the same time. You might tap your relay off the parking lights. That will give you relay power whenever high or low beams are on.
__________________
- Jeff
2000 F250 V10 5-SPD 4X4 Crew w/ 5-Star SCT X3
1949 F1 - (WORK IN PROGRESS THREAD)
  #3 (permalink)
Old 05-18-2010, 08:20 AM
blowhole's Avatar
Quote:
Aaah, very good idea, BigPig! You don't happen to know which wire that would be, and where?? (Reps given).
__________________
blowhole
  #4 (permalink)
Old 05-18-2010, 11:04 AM
wallz's Avatar
wallz wallz is offline
2002 Ford Excursion
wallz is a splendid one to beholdwallz is a splendid one to beholdwallz is a splendid one to beholdwallz is a splendid one to beholdwallz is a splendid one to beholdwallz is a splendid one to beholdwallz is a splendid one to behold
I would just run thru the firewall with the supplied leeds and go to the extra supplied fuse for "user". I believe it is hot on key.
__________________
2002 Excursion, 4x4, V-10, XLT, RS9000 shocks, true trac diff, 08 alum diff cover, interior light delete, 08 power fold/xtend mirrors, 285/75/16 BFG KM2 tires, y pipe, 5 Star tuned, front cryo powerslots with hawk pads, XRF ball joints. 50" front mounted LED bar, 10" reverse light LED bar.
  #5 (permalink)
Old 05-18-2010, 12:35 PM
BAJI26 BAJI26 is offline
BAJI26 is gaining momentum as a positive member of FTE.
Just tap it right by the park lights using a relay... simplest!
__________________
2000 2WD EX V10 6.8L
NEXT - 08 Mirrors
COMING - Backup Camera
COMING - Upholstry
  #6 (permalink)
Old 05-18-2010, 04:34 PM
2000 Ford F-250
My Garage
Quote:
I believe it was black w/green stripe. Just check the wires at your headlight socket, it's the one that powers on when you flip the high beam switch. I traced it back to the firewall just under the passenger side wiper area and tapped into it there to keep it from exposure to the elements. I then mounted my relay on the stud that holds the starter relay, and used the starter relay for my constant 12V on the Hella relay. That kept all wires on the passenger side of the engine compartment nice and neat. If you didn't see the relay you wouldn't know it was there.
I can get pics, but not today.
__________________
- Jeff
  #7 (permalink)
Old 06-06-2011, 01:11 AM
robert_l_ross's Avatar
robert_l_ross robert_l_ross is offline
2000 Ford Excursion
robert_l_ross has a spectacular reputation.robert_l_ross has a spectacular reputation.robert_l_ross has a spectacular reputation.robert_l_ross has a spectacular reputation.robert_l_ross has a spectacular reputation.robert_l_ross has a spectacular reputation.robert_l_ross has a spectacular reputation.robert_l_ross has a spectacular reputation.robert_l_ross has a spectacular reputation.robert_l_ross has a spectacular reputation.robert_l_ross has a spectacular reputation.
...for energizing the relay(s) so that the lights can come on with both the high and low beams??
Add a cut off switch...most states only allow 4 white lights to the front maximum (low beams+driving lights). Most states require all other white lights are off when the high beam lights are on.
...take it from someone who's received a ticket for too many lights to the front.
Tags
2000, 2002, driving, excursion, explorer, f150, f250, ford, installing, lights, navigator, power, relay, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
