94 F150 4.9 - Hard start/Rough idle- May/may not - Ford Truck Enthusiasts Forums
Old 05-17-2010, 11:49 PM
R202INT R202INT is offline
R202INT is starting off with a positive reputation.
Hello,
Posted before, problem is worse. 297,000 miles, new fuel pump. Fires off but skips wildly, as if it's going to shake your teeth out, may smooth up, may not. Might do it today, may not again for 3,4,5 days. Use BP or Shell midgrade, religiously. Sometimes bleeding the fuel system at the Schraeder valve will help it start, might not. Once it smooths up, no problems- runs like a new one. No miss under load or at any speed. 16.5 mpg consistently. Ambient air temp does not affect it. Might/might not do it with engine cold, might/might not do it with engine hot. I'm a Ford man all the way, but this is out of control. Any ideas? This must have happened to someone before. Any help greatly appreciated.
Thanks,
John
Old 05-18-2010, 09:53 AM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
What have you done so far? Plugs/wires/cap/rotor/coil? Have you checked the PIP/stator in the distributor? Have you tested any sensors?
Old 05-18-2010, 09:26 PM
Thanks for the reply. No, no real testing as of yet. Seems to me that any of the ignition components will either malfunction at low idle or high speed, under a load. That's what I keep saying - this rough idle only lasts for a minute or two then the engine runs like new. There has NEVER been a problem with it missing under load. Additionally, it will crank and run perfectly for several days at a time. Defective plugs, wires, etc. would not "fix" themselves. Once they fail, that's it, it never gets any better. This problem occurred 5 times today with 1 time in between that it cranked like it should. Either vigorously pumping the accelerator or bleeding the fuel rail will make it crank. Incidentally, fuel level in the tank is not a factor - makes no difference if it's slap full or close to empty.
Old 05-18-2010, 09:54 PM
DBGrif91's Avatar
Have you tried pulling the codes? See fordfuelinjection.com for a how-to.
Used Truck Shopper's Checklist WilleyJoe.62 Car/truck Buying Advice 0 06-24-2015 01:37 PM
1994 F250 - 7.5L automatic - odd engine performance problem mechanic58 1987 - 1996 F150 & Larger F-Series Trucks 5 07-02-2014 08:55 PM
My expedition is filling up with gas fumes DNJSDAD Expedition & Navigator 5 02-13-2009 06:35 PM
Help, my expedition smells like gas DNJSDAD Modular V8 (4.6L, 5.4L) 0 02-12-2009 05:16 PM
1990 Ranger 2.9 waterpump Langford Ford Ranger & B-Series 4 12-13-2008 09:34 AM
Tags
49, 50, 94, 96, bronco, difficult, engine, f150, ford, hard, hot, idle, rough, runs, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
