clutch pedal box and slave cyl questions
ive been having a clutch issue even after installing a new valair clutch/fly wheel, master cyl and heim joint. so i inspected the clutch pedal box and slave cyl.
here are a few pics of what i found
worn bushing
bent pedal box? ive never seen one like this
and heres the position of the slave on the fork untouched
and heres how far i can push it in ( not engaging clutch, the oposite way)
not sure if the slave has any issues at all, i dont think so, but i may be wrong.
but i know the box looks messd up to me
worn bushing
well if youll notice how close the nut already sits to the pedal box , bc of the worn bushing. i had to space out the bolt so i could depress the clutch. (this was before i found out my bushing was chewed up that badly) but ive ordered new bushings and they should fix me up. and i can remove the washer.
the slave cylinder is fine. The new ones you get at advance are made of plastic and don't have a bleeder screw so you bleed the system by doing what you are doing in the picture. I was also wondering what kind of clutch issues you were having. If the clutch isn't disgaging all the way I would say it would be the worn out bushing.
i guess there is an upside to me replacing all these parts here lately... by the time im done ill have a brand new truck.
