460 EFI check engine light
Old 02-02-2003, 01:06 PM
bred250's Avatar
bred250
bred250 is offline
Question 460 EFI check engine light
I have a 96 f250 460 EFI from CA. Just moved to Colo.Heater was'nt working,so I installed the correct 195F thermostat (it had a free flowing t-stat,which explained the no-heat)the truck runs great (now the temp guage is in the norm/It was on C all the time)but the check engine light is on, I'm stumped.any info would be appreciated. thanks.
Old 02-02-2003, 11:16 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
This can only be checked with an OBD-II tester. Your local Auto-Zone can check it for free. I have a tester that cost me 150 buck's. It is the same one that they will use. It actually tells you what is wrong instead of counting beeps. All 96 and newer vehicles used this diagnostics style test.
Jimmy
Old 02-03-2003, 05:41 PM
bred250's Avatar
bred250
bred250 is offline
thanks lsman1. I will try autozone and post my results.
Must be a simple problem I would hope.
Old 02-06-2003, 05:56 PM
bred250's Avatar
bred250
bred250 is offline
Well I didn't make It to Autozone but I disconnected the negetive on the battery cable for 2 minutes and It went away.
(got it from a friend) thought I'd pass it on anyway.
Old 02-06-2003, 10:21 PM
merc460's Avatar
merc460
merc460 is offline
What you did by disconnecting the battery, was erasing the ecm
memory. The light may come back if the problem is still there. Eric
Old 02-07-2003, 06:28 PM
bred250's Avatar
bred250
bred250 is offline
Angry 460 EFI check engine light
I did go to autozone and the OBD-2 read sytem too lean
(bank1 bank2)sytem too lean bank 1bank2
any suggestions?
hambone460
10-09-2021 04:26 AM
Jaredpizzino
01-06-2016 07:20 PM
ycanby
04-20-2015 08:52 PM
WWB F250
07-05-2006 08:00 AM
aintskeered
07-12-2002 08:27 PM
Quick Reply: 460 EFI check engine light
