Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 02-02-2003, 12:46 PM
jeff moon jeff moon is offline
Garage is empty, add now
jeff moon is starting off with a positive reputation.
93 lightning-too much compression?
I am going from 65.5 cc head chamber volume to 61cc. how much should this add to my compression ratio - I have a 351w .030 over
(93 lightning) the motor has 2000 miles on stock rebuild. It has a 6 psi ford motorsports supercharger (powerdyne) I have a new set of trick flow twisted wedge heads (61cc) that i want to installwould this increase my compression too much for the supercharger? I was told the
original gt40 heads have 65.5cc ( but i dont know for sure?) any answers or advice would be greatly appreciated Thanks jeff moon (my compression ratio right now should be around 8.8? right now)
  #2 (permalink)
Old 02-03-2003, 07:00 AM
DeenHylton DeenHylton is offline
DeenHylton is starting off with a positive reputation.
Weiands tech manual on supercharging states you need to keep your "effective" compression ratio at 12:1 or below when running pump gas (92 Octane). According to their charts 8.5:1 compression and 6 pounds boost equals 12.0 effective compression...the maximum you should be running.
Your guess-timated 9.3 compression with 6 pounds boost will equal 13:1 effective compression. I'd say you'll have to run some sort of boost retard timing control to control detonation...Deen
__________________
1989 F250 460 C-6, RV cam, headers, duals, K&N, shift-kit, now 4.10's.
Tags
150, 93, boost, compression, engine, equal, f250, ford, lighting, lightning, ratio, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
