air bag light on
09-29-2013, 11:07 AM
on
air bag light on
Not sure if its just a v-10 issue but I recently noticed my airbag light is on on the dash.....it blinks 1......1.1 for a few times then stays on. So the code flashing is 1. 2 any ideas on what it is?? Thanx in advance!!
09-30-2013, 09:10 AM
09-30-2013, 11:13 AM
It's got nothing to do with the V10, it's an issue with the airbag system which doesn't care about which engine is under the hood.
Lamp Flash Codes vary by year and model. Using a generic list from somewhere on the internet is too often going to be incorrect.
10-05-2013, 11:20 AM
on
Does you on/off light work when you turn the passenger side airbag on or off?
10-05-2013, 11:30 AM
on
I havent tried that? I will in a lil bit
10-05-2013, 01:42 PM
The PAD has nothing to do with a LFC 12 code.
Take it to a shop that has a good scanner and have them pull codes and reset the module.
walkinghorse
1999 to 2016 Super Duty
04-19-2009 09:38 PM
valo
1983 - 2012 Ranger & B-Series
01-06-2005 08:10 PM
gwmontgomery
Electrical Systems/Wiring
06-29-2000 04:36 PM
