how do i know if my tuck has a keyless entry? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-15-2011, 05:07 PM
f250towrig f250towrig is offline
f250towrig is starting off with a positive reputation.
Quote:
Originally Posted by jimjoebob99 View Post
I just had to deal with this and got a new key fob last week. Got it all programmed and it works great. The module is directly behind the little inset in the dash to the lower right of the steering column. You know, it looks like a place you might put keys or change right next to where your right knee would be. If you remove the lower trim panel there, it says that it's the keyless entry module or something to that effect (I don't believe that you can read it while the lower trim is in place). That is where it is in my truck and I have a 95. The plug that your looking for that has the wires you need to jump for programming is taped to the harness underneath the module and I believe that it is a gray plug.
The sequence for programming the remote is:
1. Turn the key to the on position.
2. Use a jumper to short the two wires in the connector under the dash (the grey two wire connector) and the locks will cycle from locked to unlocked, to let you know that it's in program mode.
3. Press any key on the key fob that you want to program. The locks will cycle from locked to unlocked again to confirm that the remote has been programmed.
4. Repeat step 3 for any additional remote that you want to program with it (I believe that the system can support up to 4 key fob's).
5. Remove the jumper wire and turn the ignition off. The locks will cycle to locked and then to unlocked to confirm that your exiting programming mode.
Note: If you add or remove key fob's from the truck, you have to program all of them again each time you program the module.
I'm not sure about getting one from the junk yard but i've heard it works and is plug and play as long as you have the correct harness in the truck. I also have the blinking theft light on the dash and believe that this is part of the system. I'll try to take some pictures today if anyone needs them in a little bit. I did quite a bit of research on this a while back and hope that this helps everyone out.
Here is a link to the key fob that I purchased. 1993 1994 1995 94 95 FORD EXPLORER KEYLESS KEY REMOTE: eBay Motors (item 230469850703 end time May-07-10 11:47:38 PDT) I believe that any one around this year from a Ford Truck will work as long as it has the same FCC ID and it's the 3 button layout (you don't need the 4 button because you don't have a trunk).
So I know this is an old post, but I found it today and tried t, worked great, its nice to have power locks.
  #32
Old 08-15-2011, 05:58 PM
breno1987's Avatar
breno1987 breno1987 is offline
breno1987 is starting off with a positive reputation.
This is the module I found behind my little cubby hole to the right of the steering column. I'm assuming it's not RKE... just thought I'd give it a shot though... thoughts?
  #33
Old 08-15-2011, 07:57 PM
Ill snap a good picture, but I did not need to remove any dash pieces to get to it. It should the a grey plug taped to the wires with two round probes in the plug, those are the ones your jumper together with the key on.
  #34
Old 08-16-2011, 07:17 AM
jimjoebob99 jimjoebob99 is offline
jimjoebob99 is gaining momentum as a positive member of FTE.
Quote:
Well i'm glad that it worked out for you. It makes it great when I go places because I leave my key fob in the cup holder when i'm at home but when i'm out and about, I hide the keys on the floor board and stick the key fob in my pocket. It's a lot easier carrying that around compared to my set of keys. I also have the backup plan though. If my key fob ever dies, I always keep a spare key to the doors and ignition in my wallet. Don't ask me how I found out the hard way on that either.
  #35
Old 08-16-2011, 07:19 AM
Quote:
You should be able to see the grey connector with the two round pins from the bottom like f250towrig said. If you go back a little bit in the thread, I posted a picture of the module and the connector.
Edit: I see that you have a 92' and I don't think that they came with RKE in that year.
  #36
Old 08-16-2011, 08:39 AM
ChristopherN ChristopherN is offline
ChristopherN is starting off with a positive reputation.
Quote:
Originally Posted by superduty4x4 View Post
I don't think RKE was an option until 94 or 95 sometime so you are out of luck for the "Easy Button" method
Then my Brother's Bronco he used to have wasn't a 94....
  #37
Old 08-16-2011, 01:01 PM
kosmo01 kosmo01 is offline
kosmo01 is starting off with a positive reputation.
After reading this, I am going to try it. I just bought 1 off E-bay for close to $20.00, with shipping to Canada. My theft light was flashing, when I opened the door. So I thought I would give it a try, would be nice to have. If any body is looking for one I typed in ford 1995 remote keyles on E-bay
  #38
Old 08-16-2011, 08:37 PM
  #39
Old 08-16-2011, 09:38 PM
ostrx250 ostrx250 is offline
ostrx250 is starting off with a positive reputation.
kewl i need to check for one would be nice
  #40
Old 08-16-2011, 10:46 PM
bigred1992's Avatar
bigred1992 bigred1992 is offline
bigred1992 is starting off with a positive reputation.
Sometimes I really hate having a 92
  #41
Old 08-17-2011, 12:13 AM
Midnite1987's Avatar
Midnite1987 Midnite1987 is online now
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
It just so happens that i have the lower piece off on my truck and could get a pic for you guys. this is directly behind the "pocket" in the lower piece.
i ordered 2 remotes off ebay yesterday so ill see how it goes.
  #42
Old 08-17-2011, 01:49 AM
Alec94F150XL's Avatar
Alec94F150XL Alec94F150XL is offline
Alec94F150XL is starting off with a positive reputation.
Quote:
Originally Posted by fishforlife2007 View Post
ok...with that picture, i am unsure now...like i said mine is a box that is about robbins egg blue in color. when i took a second look at it i noticed that it has 2 connectors that i can see, and they are comming out the side of the box
For me it was my Air Bag Module, it looks like this. I am absolutely positive on this information, I had to unplug it because my air bags were malfunctioning/broken (not deployed). You can find more info on the box and what it does.
  #43
Old 12-24-2011, 04:32 PM
Suedeuno Suedeuno is offline
Suedeuno is starting off with a positive reputation.
I have an 08 F-150 and it has a blinking anti-theft device (I assume) on the dash but no power locks.
  #44
Old 12-24-2011, 06:14 PM
Quote:
Your truck doesn't fot into this forum.... This is a 87-96 thread...
  #45
Old 12-24-2011, 09:26 PM
blkF250HD's Avatar
blkF250HD blkF250HD is offline
blkF250HD is gaining momentum as a positive member of FTE.blkF250HD is gaining momentum as a positive member of FTE.
FWIW my 97 doesn't have the "Theft" light. I do believe there is a difference between RKE and having a factory alarm/anti- theft. You can have both, or no anti-theft like mine does.
Autoenginuity keyless entry cassenbl Excursion - King of SUVs 13 04-07-2015 01:33 PM
keyless entry and engine remote start for diesels? nickt916 1999 - 2003 7.3L Power Stroke Diesel 5 11-02-2012 07:53 PM
2003 F-250 Keyless entry problem 95PSDieselP 6.0L Power Stroke Diesel 4 04-08-2012 01:02 PM
keypad keyless entry twayne85 1999 - 2003 7.3L Power Stroke Diesel 0 08-03-2011 11:53 AM
Factory Keyless entry camerory 1999 to 2016 Super Duty 0 01-16-2011 08:34 PM
Tags
1996, 1999, 2008, change, entry, f250, f350, factory, find, ford, keyless, module, remote, replacement, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
