302 Water pump - Ford Truck Enthusiasts Forums
302 Water pump
Old 05-17-2010, 12:47 AM
dmt_73ford's Avatar
dmt_73ford dmt_73ford is offline
dmt_73ford is starting off with a positive reputation.
Question 302 Water pump
I am a new member to FTE but have been a follower for a short time, this is my 1st post. I have a 73 F100 with a 302 & C4 auto trans. The tranny needs a rebuild so I havent driven lately and has sat for about a year since I last started her up. I decided to try to get her running again but have hit a few snags. I had to replace the fuel pump to get her started. Then with the first startup she dumped a load of water. I picked up a new water pump and got the old one out. Then I discovered a hole above the upper right water passage on the block. I have a feeling this is a bad sign. Has anyone seen this before? Does this mean my block is rotted?
Old 05-17-2010, 01:05 AM
JAYS69F100's Avatar
JAYS69F100 JAYS69F100 is offline
JAYS69F100 is starting off with a positive reputation.
From what I can see, it looks like your timing chain cover is corroded away. The aluminum piece between the water pump and block.
Old 05-17-2010, 03:10 AM
RVDan's Avatar
RVDan RVDan is offline
RVDan is starting off with a positive reputation.
Quote:
Nope, just your timing cover is rotted
Old 05-17-2010, 12:12 PM
eric138 eric138 is offline
eric138 is starting off with a positive reputation.
I had the exact same problem and just patched it with jb weld. It is probably not the best solution but the only thing I could think of other than replacing the whole timing cover. It has lasted about a year and a half like that with no problems. There is not much pressure behind it. To do it I put a little piece of wax paper in the vent then covered the outside with the jb weld let it set and took the wax paper out. Quick Fix.
Old 05-17-2010, 07:19 PM
dmt_73ford's Avatar
Thanks! I will probably pull the motor, its a project truck anyway.
Old 05-17-2010, 10:04 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Looks like you have a lot of degreasing to do.
Old 05-18-2010, 12:08 AM
dmt_73ford's Avatar
Anyone have any idea how much time and hassle I have in replacing the timing cover? Am I going to get into popping the oil pan?
Ya dkf, the grease is everywhere, all my bolts were caked. Its probably going to take me most of my weekend cleaning the grease from the whole underside so I can yank the tranny.
Old 05-18-2010, 01:54 AM
RVDan's Avatar
Its always troublesome getting the bottom of the timing cover to seal to the oil pan again without loosening off the oil pan
Old 05-18-2010, 09:33 AM
dkf's Avatar
dkf dkf is offline
The oil pan gasket could more than likely use replacing anyway.
Old 05-18-2010, 12:31 PM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
Yea, there are four bolts in the bottom of the timing cover that attach to the oil pan. As stated you'll probably have to loosen a few of the oil pan bolts back from the front to get the pan to drop some to let the timing cover bolt holes line up with the ones in the block. The timing cover gasket set will come with new little pieces of cork gasket to replace the part between the timing cover and oil pan. It's just a little triangle kinda piece. I had to do mine when I replaced my water pump because one of the bolts broke off flush with the block. I had to pull the timing cover drill out the bolt and retap the hole.
On the degreasing. Purple power works great!! Buy the big jug and put it in a spray bottle.
After Market (Non-OEM) Water Pump Woes PaysonPSD 1999 - 2003 7.3L Power Stroke Diesel 31 05-12-2010 05:08 AM
water leaking,new water pump?? mtl93ranger 1999 - 2003 7.3L Power Stroke Diesel 2 01-29-2008 10:32 PM
Water Pump Wheeping ctch88 1978 - 1996 Big Bronco 8 08-12-2005 01:10 AM
How much coolant? RedTaurus94 1999 - 2003 7.3L Power Stroke Diesel 4 10-20-2004 10:13 PM
Massive amount of gas in the oil Pheonix BlackWolf Oil & Lubrication 4 10-20-2002 05:29 AM
Tags
1967, 1968, 1978, 302, 302waterpump, 69, 73, bolts, econoline, ford, ho, pump, require, sealant, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
