Crew Cab Rear Speaker Removal
Old 02-02-2003, 10:05 AM
Fords For Ever's Avatar
Fords For Ever
Fords For Ever is offline
Question Crew Cab Rear Speaker Removal
Before I replace the factory speakers on my 2003 F250 Crew cab I thought if someone had already done it they could share some info. My Haynes manual has no info for the rear speakers, located near the C-pillar, not in the rear door. Both this site and the Haynes manual cover the front speaker removal.
It looks like all I need to do is remove the door sill trim and the vinyl trim covering the C-pillar. The trim is held on by plastic "christmas tree" fastners right? The seat belt tensioner will not allow for the complete removal of the trim but I think I can get to the speaker. Don't want to break any trim pieces. Thanks in advance for any info/guidance.
Old 02-02-2003, 02:49 PM
FYRDOC's Avatar
FYRDOC
FYRDOC is offline
I have not done mine yet...but everything your describing sounds right.....I think I remember reading in here somwhere about removing the seat belt tensioner...not really sure how...
Old 02-11-2003, 01:40 PM
LincolnHayes's Avatar
LincolnHayes
LincolnHayes is offline
This swap is not that hard, jusging from the date of this post, I assume you have already performed the swap, but I just thought I would add a little inisght. you were correct in the disassembly of the trim, but be very careful when reassembleing the trim. I broke more fasteners by putting the trim back on than taking the trim off. make sure you fastener is completely lined up with the hole.
Good Luck
LH
Old 02-11-2003, 04:00 PM
Fords For Ever
Yeah it is done. The only unusual tool you need is a #47 Torx head to remove the seat belt pulley. The vinyl trim is a bit of a PITA to put back on. The infinity kappa 572.5 are a BIG improvement. Got them off E-Bay for way less than any shop around here. Then I put in an Alpine 7893 HU with the 10 ga power cable and now it sounds much better than stock! Can't believe they put such a weak system in a 35K truck, but I guess thats all the average consumer wants.
Old 03-21-2012, 10:42 AM
SsOnLaIkDe's Avatar
SsOnLaIkDe
SsOnLaIkDe is offline
Better Late than never
Hey guys, looks like I'm about 10 years late on this project. I was wondering if I have to remove the seatbelt to get the speaker out. I'm going to be doing this project a morning before work, so I want to make sure I have enough time. Any advice is appriciated
4x484150
08-02-2016 08:34 AM
2009kr
2017+ Super Duty
09-02-2015 09:21 AM
jeremiah77
02-07-2015 09:36 PM
ashdex
02-11-2014 04:35 PM
searay5150
04-08-2011 09:59 PM
Quick Reply: Crew Cab Rear Speaker Removal
