351 W in an early bronco?
05-16-2010, 02:47 PM
on
Did Ford ever offer the 351 Windsor in the early broncos. Seems like some friends of mine in Boulder had a 68 or 9 with one that I think they bought new.
05-16-2010, 03:19 PM
Never offered in a 66-77 Bronco. But a number have been swapped in.
05-17-2010, 03:25 AM
on
If you want to do one it is best to have a 2" body lift to clear everything.
05-19-2010, 12:10 AM
on
mine in my 77 fits fine without a body lift. but i would be good for putting on aftermarket headers. and other goodies.
05-19-2010, 06:53 AM
Quote:
Originally Posted by
patf223
Have fun getting the drivers side valve cover off if you ever need to.
05-19-2010, 11:55 AM
Have a 351 W in my 71 Bronco Sport for years with a C-6 behind it. Love the engine and its great fun to drive.
05-19-2010, 08:46 PM
on
gfw1985
My Ford Motorsport Valve covers were easy to change out with the 2" body lift. Best part is does not mess with your suspension & you can run 33's
05-20-2010, 08:26 PM
on
Was there much modification to fit a C-6. Ive got a solid C6 I'm planning on putting in and I see you got one in yours.
05-21-2010, 06:15 AM
Mine was a small block bell housing. Dont remember where I got it. Bolted right up. Ordered the adapter from Advance Adapters and bolted up the tcase.
Pretty easy install.
05-21-2010, 11:24 AM
on
Yeah my 87 f150 with a 302 came with a c6. How much was the adapter for the transfer case? Did you have to get new driveshafts?
05-21-2010, 03:15 PM
Adapter was around $600 at the time...that was 10-12 years ago. Do not know what it would cost now.
05-21-2010, 03:33 PM
05-22-2010, 07:56 AM
on
Its nice to have a C6 but a C4 is plenty, the loss in HP outweigh the C4 to the C6 Swap IMHO. A built C4 will handle 1000hp.
05-22-2010, 08:15 AM
But my C6 has lower 1st and 2nd gears from a newer trans. Dont remember the model, but my transmission guy added the lower gears to help out the rear end gears.
05-22-2010, 08:19 AM
on
jd58980
That is good but you lose 40hp in the swap, Build the SBF 500hp
