Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-15-2010, 10:15 PM
TIKT B8 TIKT B8 is offline
Garage is empty, add now
TIKT B8 is starting off with a positive reputation.
Wiring diagram
I am ordering my lockpick to install an oem reverse camera on the oem navigation unit and I am needing some wiring help. I need to find out what color and where the reverse wire is. I assume it is a black/pink wire like the F150? I know I can tap into the reverse wire at a tail light, but the lockpick will be the one connected to the reverse wire, so i would prefer to use the reverse wire in the dash/kick panel. Does anyone happen to have this wiring diagram? Thanks for your help.
__________________
2007 Expedition Limited White Sand
  #2 (permalink)
Old 05-16-2010, 07:02 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Looks like gray and brown to the trailer connector. There's a fuse for it in the tow electrical box on top of the radiator shroud. Position 63 for the fuse.
Sorry I can't make this smaller and still readable.
Click the image to open in full size.
-- Chuck
  #3 (permalink)
Old 06-01-2010, 03:29 PM
Cabinboy07 Cabinboy07 is offline
2007 Ford Expedition
Cabinboy07 is starting off with a positive reputation.
Hey man, if you are electrically inclined, I would love to see you further mod your system to add a video feed in from your rear OEM DVD system (if you have one), to your OEM nav unit, probably through your lockpick. That is a task that I am thinking of taking on, but am less inclined electrically than mechanically. I would love for a little guidance in this area.
  #4 (permalink)
Old 06-02-2010, 07:23 PM
I am not that smart or confident to try that on my expy.
Chuck S - I also found that reverse wire that is under the passenger side door sill. There are 2 green/brown wires that go back to the tailights.
My lockpick should be here this friday and I might try to install it in the next two weeks as i am going on a trip for a few days.
__________________
  #5 (permalink)
Old 06-03-2010, 07:26 PM
st381 st381 is offline
st381 is starting off with a positive reputation.
I am also doing a lockpick reverse camera install. Where are these reverse wires under the passenger door? Do you have a pic? I would love to hear about your install.
Here's a thread I started to describe my experience:
Coastal E Tech License Plate Rear Camera Install - Ford Truck Enthusiasts Forums
  #6 (permalink)
Old 06-04-2010, 12:04 PM
From what I understand about the Lockpick, it comes with a harnes that plugs directly into the Nav harness. I don't think that you will need to track down the reverse wire at all. I would think that the Lockpick would come with detailed instructions, otherwise it really wouldn't be worth the $$$.
  #7 (permalink)
Old 06-04-2010, 12:44 PM
The harness is pre-built for all the radio controls but you have to hook one wire to the reverse wire in order to have the rear camera image appear automatically when the vehicle is placed in reverse. Hence, I need a good place to tap into the reverse wire.
  #8 (permalink)
Old 06-04-2010, 03:16 PM
There is no reverse wire in the original stereo wiring so you have to tap into one.
The ford 360 lockpick works for all 06-09 FLM nav units so I doubt the instructions are that detailed on giving you a reverse wire for each FLM vehicle.
__________________
  #9 (permalink)
Old 06-17-2010, 12:37 PM
dm ford rebal dm ford rebal is offline
dm ford rebal is starting off with a positive reputation.
is their a web site 2 get a wire lay out
Tags
2007, 360, camera, diagram, dvd, expedition, f150, ford, installing, lockpick, oem, reverse, system, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
