Hydraulic Clutch Conversion Kit - Ford Truck Enthusiasts Forums
Old 02-02-2003, 12:28 AM
Crazy_John69 Crazy_John69 is offline
Crazy_John69 is starting off with a positive reputation.
Cool Hydraulic Clutch Conversion Kit
Howdy All I Have A 1976 Ford F-250 Hi-boy W/ 42's a Modified 390fe and a Np435 W/ divorced Np205. I've Looked And Looked For A Hydraulic Clutch Conversion Kit For My Truck And Have Been Unsucsessfull I Would Apreciate Any Help If Anyone Has Found A Kit For This Truck Or A Trick I Can Use To Help With The Manual Linkages.
Old 02-02-2003, 06:07 PM
73Custom 73Custom is offline
73Custom is starting off with a positive reputation.
What's wrong with your linkages? Mine were getting worn, so I replaced all the bushings (from Dennis carpenter) and lubed it good. There are bushings were the clutch pedal pivots, on the rod going through the floor, and the equalizer shaft (mounts between frame and bellhousing). I'm very pleased with how much better it is...
Marty
Old 02-02-2003, 10:10 PM
Nothing Lines Up. I've Tried Everything But To Make It Work I Have To Drill New Holes In The Frame And Shim It. I Cant Figure Out How It Worked Before. It Looks So Simple But Its Driving Me Nuts. I Thought If I Could Find A Hydro Kit It Would Make It Easyer.
Old 02-03-2003, 08:31 AM
Sounds like something isn't right. Sounds like someone has swapped motors and left you with the incorrect pieces. Go to a salvage yard (or friends truck) and get the correct linkages to compare to yours. Each of the different engine families require different clutch linkages.
Or your engine could be out of alingment. Make sure the engine and trans mounts are intact and tight.
Marty
Old 02-04-2003, 10:06 PM
Scot's Avatar
Scot Scot is offline
Scot is starting off with a positive reputation.
I used hard 3/8 24 rod and heim joints on my highboy.
HELP! Need NP435 clutch fork infinite-foamies 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-19-2016 04:23 PM
Hydraulic Clutch Conversion Rogger2006 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 09-08-2014 03:00 PM
zf5 300 l6 swap dylansf23 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 04-08-2014 09:34 PM
83 F-250 NP435 To Hydraulic Conversion jeep-rally 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 09-18-2012 02:23 PM
Converting 72 F100 4WD to hydraulic clutch. Elwood72 1967 - 1972 F-100 & Larger F-Series Trucks 1 04-09-2011 08:21 PM
Tags
100, 1979, 1996, 73, clutch, conversion, conversions, diesel, f100, f250, ford, hyd, hydraulic, kit, kits, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
