LOUD BEEPING - Ford Truck Enthusiasts Forums
LOUD BEEPING
Old 05-15-2010, 07:12 PM
I-6 LOVER I-6 LOVER is offline
I-6 LOVER is starting off with a positive reputation.
Question LOUD BEEPING
I get this loud beeping every once in awhile in this '95 F-150 that i am working on to get it back on the road. WHAT could this be? It is only when I have the key on - not started and only once in awhile.
Thanks
Old 05-15-2010, 08:38 PM
fishforlife2007's Avatar
fishforlife2007 fishforlife2007 is offline
fishforlife2007 is starting off with a positive reputation.
in all seriousness now... can you describe this beep any more? is it like a digital beep? this is confusing because i have never heard of this. is it coming from your speakers?
Old 05-15-2010, 11:22 PM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
On your question - the '92-'96 trucks have a buzzer that makes a rather annoying sound when the key is in the ignition (even when turned off) and a door is open. Then there is another buzzer, that one beeps when the ignition is on but the engine ain't running, again door needs to be open to trigger it.
Old 05-16-2010, 12:52 AM
Roger T. Pipe's Avatar
Roger T. Pipe Roger T. Pipe is offline
Roger T. Pipe is starting off with a positive reputation.
When either the 'check engine' 'ABS' or 'AIRBAG' lights have blown out or have been removed, you'll get an intermittent beeping sound like you described. See if these bulbs are indeed good. Chances are one of them is blown out or removed. I would guess that Ford installed this as a back up safety feature? Hope this helps!
Roger
Old 05-16-2010, 06:16 AM
KevinGnWV's Avatar
KevinGnWV KevinGnWV is offline
The village idiot.
KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.
Quote:
Roger
I never knew that. Learn something new everyday, even at my age Thanks!
Old 05-16-2010, 07:09 AM
fatboyf150's Avatar
fatboyf150 fatboyf150 is offline
fatboyf150 is starting off with a positive reputation.
roll your window down, switch the key off, close the door, and pull the headlight switch and see if it had the same beep.
Old 05-16-2010, 09:56 AM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
I've deleted the pointless, rude and off-topic posts in this thread...but it looks like it's already too late. Way to go guys, driving away a new member who simply came here looking for some help. But as long as you could get a laugh out of it at his expense, I guess that makes it okay, huh?
Old 05-16-2010, 10:30 AM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
im sorry mister dan....
not...
a beeping when the key is on could be anything
wow talk about narrowing it down...
gee could be something after market
so now how bout fixing the sticky adding a FAQ section
u know Frequently Asked Questions
and add some common mods and how to do them
Old 05-16-2010, 01:34 PM
Quote:
And in the process you wiped out my post where I was trying to calm the situation down but more importantly I was telling him what kind of buzzers his truck have and when each of them goes off... No hard feelings man, but sometimes edit works better than delete
You gonna do this? Cause mods have other stuff on their hands, such as dealing with your own behavior as exemplified below:
not...
Old 05-16-2010, 11:01 PM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputation
How about you start a thread asking for a FAQ and provide links to some how-to mods? It's your forum. Your mod is not going to do all the work for you. You have to provide the links to things you want to see in a sticky. Perhaps your forum moderator will add a FAQ to the sticky if he sees fit. But unless you change your ways and act like an adult, I doubt if he will consider your request as genuine.
Old 05-19-2010, 12:21 PM
Quote:
Yes, it sounds like it's coming from my speakers. I know it's not the usual buzzing, dinging noises that we get from doors being opened as as far as I can tell all the idiot lights work. Also, there is NOTHING after-market in this rig.
<b>I didn't get chased off, I just walked away for awhile to see IF I could get some real help!<br>Thanks to the ADULTS on this forum for their replies.</b>
Old 05-19-2010, 02:55 PM
HrdDrv's Avatar
HrdDrv HrdDrv is offline
HrdDrv is gaining momentum as a positive member of FTE.HrdDrv is gaining momentum as a positive member of FTE.
There is a black box under the dash, to the right of the gas pedal that chimes/beeps, mabe etc. Pull it and see if it cures it. On mine, though, I forget my lights were left on (rainy weather) but my new battery takes care of that mistake. (I wanted to have my radio on when my doors were open, and key on ACC, is why I pulled my black box...) Good luck and let us know.
Old 05-19-2010, 07:22 PM
Quote:
That's its own buzzer tho, and it won't play the noise through the speakers... Is there a factory radio that makes a beeping noise under certain conditions? I know my aftermarket Sony unit will beep three times when it shuts off, did any factory radio had a similar feature?
Old 05-19-2010, 10:19 PM
HrdDrv's Avatar
Just gonna toss this one out there for a bite...
The other day I took my stepson to the parts depot for tune-up schtuff for his F-150. As I was driving, the radio starts going nutz. I start looking around the dash for lights. Turns out his cell phone was causing interference when someone texted him...beeping, tapping noises, etc.
Old 05-19-2010, 10:35 PM
KevinGnWV's Avatar
The village idiot.
I get feedback sometimes through my speakers from the cell phone. Factory am/fm tape.
I think mines screwed anyway. The ONLY time my truck beeps is when I open the door and REMOVE the keys with the truck running. Yep, it comes right out and starts beeping. Other than that, I can run ACC stereo on, doors open and nothing. Good thing is the ignition still locks
Beeping noise 87&97Aerostrar Aerostar 21 02-17-2017 09:06 AM
5 Beeps once when door opens - 2002 F250 CC99 1999 to 2016 Super Duty 3 10-06-2016 09:23 AM
"Wiring fault on trailer" message TexasTroop 1999 to 2016 Super Duty 88 03-23-2015 01:45 PM
Bleepin' beepin' Rogue_Wulff Ranger & B-Series 6 03-29-2011 10:33 AM
4 sets of 4 beeps when f150 started r14tier Electrical Systems/Wiring 2 11-25-2010 07:31 AM
Tags
06, 1995, 2003, 2005, beep, beeping, dash, f150, ford, intermittent, noise, start, times, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
