PO401 code
Old 05-15-2010, 02:23 PM
JHUBB58's Avatar
JHUBB58
JHUBB58 is offline
PO401 code
my edge evolution programmer keeps saying unknown PO401
anyone know what that is
Old 05-16-2010, 05:27 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Your programer dosn't have enough code info in it's program.
P0401 code is a common fault code.
It is a low flow failure in an EGR system test.
Get the code read with a scanner and it will tell you the same thing.
Could be any one or more of the following;
1. Blockage behind the EGR valve in the intake manifold.
2. DPFE, it's connection hoses, plugup etc.
3. Blocked metal pipe the DPFE is connected to.
4. Vacuum control regulator or hose between the intake and the EGR valve.
5. Faulty EGR.
Old 05-16-2010, 12:03 PM
JHUBB58's Avatar
JHUBB58
JHUBB58 is offline
thanks ill check it out
Old 05-17-2010, 05:19 PM
Lance1601's Avatar
Lance1601
Lance1601 is offline
i had this. changed my dpfe sensor, light never came back.
Old 05-17-2010, 06:07 PM
JHUBB58's Avatar
JHUBB58
JHUBB58 is offline
i think i have one of those laying around off of my old engine i wonder if i put that on there if it would get me by for a while
Old 05-17-2010, 10:27 PM
Bluegrass 7
The 401 code is a test result.
The test is of a total system operation as set up by PCM routine.
If one part fails, the code is set.
DPFE is only one part so no guarrentee it is the problem if the code and CEL does not go off after 2 drive cycles.
Look at the other 4 items as possibilities if your not lucky.
Good luck.
RDockery
1997-2006 Expedition & Navigator
05-27-2016 12:19 PM
Montana Mike
08-26-2014 08:15 PM
2oo1 4x4
1997 - 2003 F150
05-15-2014 08:05 PM
2na
1999 to 2016 Super Duty
11-20-2008 12:35 AM
js2326
1997 - 2003 F150
12-31-2003 06:46 PM
Quick Reply: PO401 code
