PO401 code - Ford Truck Enthusiasts Forums
PO401 code
Old 05-15-2010, 03:23 PM
JHUBB58's Avatar
JHUBB58 JHUBB58 is offline
JHUBB58 is starting off with a positive reputation.
PO401 code
my edge evolution programmer keeps saying unknown PO401
anyone know what that is
Old 05-16-2010, 06:27 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Your programer dosn't have enough code info in it's program.
P0401 code is a common fault code.
It is a low flow failure in an EGR system test.
Get the code read with a scanner and it will tell you the same thing.
Could be any one or more of the following;
1. Blockage behind the EGR valve in the intake manifold.
2. DPFE, it's connection hoses, plugup etc.
3. Blocked metal pipe the DPFE is connected to.
4. Vacuum control regulator or hose between the intake and the EGR valve.
5. Faulty EGR.
Old 05-16-2010, 01:03 PM
JHUBB58's Avatar
thanks ill check it out
Old 05-17-2010, 06:19 PM
Lance1601 Lance1601 is offline
Lance1601 is starting off with a positive reputation.
i had this. changed my dpfe sensor, light never came back.
Old 05-17-2010, 07:07 PM
JHUBB58's Avatar
Quote:
i think i have one of those laying around off of my old engine i wonder if i put that on there if it would get me by for a while
Old 05-17-2010, 11:27 PM
The 401 code is a test result.
The test is of a total system operation as set up by PCM routine.
If one part fails, the code is set.
DPFE is only one part so no guarrentee it is the problem if the code and CEL does not go off after 2 drive cycles.
Look at the other 4 items as possibilities if your not lucky.
Good luck.
Codes PO401, 171 and 174 RDockery 1997-2006 Expedition & Navigator 3 05-27-2016 01:19 PM
Just want to fix Code 401 for trade in Montana Mike 6.0L Power Stroke Diesel 4 08-26-2014 09:15 PM
PO401 code and misfires on 3 and 7 2oo1 4x4 1997 - 2003 F150 1 05-15-2014 09:05 PM
OBDII fault PO455 and PO401 2na 1999 to 2016 Super Duty 3 11-20-2008 01:35 AM
Codes PO401, PO174, PO308 js2326 1997 - 2003 F150 3 12-31-2003 07:46 PM
Tags
2006, 401, 54, 60, 68, code, diesel, f350, falut, ford, p0401, po, po401, scan, triton, truck, v10, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
