Superduty Rear Axle - Ford Truck Enthusiasts Forums
Superduty Rear Axle
Old 05-15-2010, 09:20 AM
greywynd greywynd is offline
greywynd is starting off with a positive reputation.
Superduty Rear Axle
Wondering about the Superduty rear axle from this truck that I had to make into a trailer. I never did anything to the rear, but as he pulls it with the tractor, it 'clicks'. I'm thinking that it's the meshing of the gears, and it's likely low on gear lube knowing how this poor thing was maintained.
Would it be possible, or how would I go about taking the gears out? I'm thinking that I would either have to make a cover for the front of the pumpkin to keep oil in, or take the wheel assemblies apart and grease the bearings so they don't die an unfortunate death. If this thing happened to have a LS in it, would it be usuable in any of my 'lighter' trucks? I'm thinking that there's no way it would fit, seeing as it looks huge compared to even the F350 rear axles?
Old 05-15-2010, 09:31 AM
johnboggs21's Avatar
johnboggs21 johnboggs21 is offline
johnboggs21 is starting off with a positive reputation.
F250-F450 all had the same rear axles IIRC.
Old 05-15-2010, 09:24 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Depends, some F-super Dutys as they are called had Dana 80 rear axles.
Old 05-15-2010, 09:46 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
Quote:
nope.
350 and 350 single rear wheel had sterling 10.25 gear with parking brake.
350 dual wheel pickup had sterling 10.50 rear with parking brake..
superduty had dana 80 rear with no parking brake.
tha parking brake on a superduty is on the back of the trans.
Old 05-15-2010, 10:20 PM
Wonder why the F-trucks had Sterling axles, and vans had Danas? My motorhome has a Dana 70.
Old 05-15-2010, 11:25 PM
Quote:
Originally Posted by tjc transport View Post
nope.
Yes, this rear axle is definitely heavier than the one in my dually, and has the disc brakes, and the parking brake was on the rear of the tranny.
I didn't realize the dually's had a different axle than the SRW though, good to know!
Old 05-16-2010, 12:11 AM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
The D80 is a full floater, which means you can pull the axle shafts and cut their bolt-flange ends off then reinstall just the flanges as caps for the hubs - no shafts to engage the diff means axle will likely stay nice and quiet and roll easier too.
Old 05-16-2010, 08:05 AM
LCAM, that's what I was thinking about doing, but wasn't sure if that would create any issues. I had just been thinking that if the 'innerds' were usable in anything else it would have been nice to save them, but other than another superduty it's not very likely.
Old 05-16-2010, 10:18 AM
i ain't rite
but the full floater uses the axles to pull lube oil out of the diff to lubricate the bearings. if you pull the axles, the wheel bearings will not last very long before they burn up.
Old 05-16-2010, 10:38 AM
FL-Mudd-Duck's Avatar
FL-Mudd-Duck FL-Mudd-Duck is offline
FL-Mudd-Duck is starting off with a positive reputation.
seal up the axle tube cap end tap hole for oil plug and fill
Old 05-16-2010, 02:14 PM
How does that work out? It ain't like the axle shafts are rifled on the outside to help carry oil from the pumpkin outboard... I know in my Sterling axle if you fill to capacity with the axle level oil will just travel down the axle tubes and reach the bearings and leak out the hub end if the axle shaft ain't in place, so the bearings will get enough oil even with the axle not turning at all. With a D80 turned into a trailer axle when he cuts the shafts he can overfill the axle by quite a bit, with the gears not turning there's nothing to generate heat in there and expand the oil and potentially push it out the vent port. Heck my drive axle is always a quart over and never gave me any issues, even tho it gets plenty hot after several hours of running on the freeway...
Old 05-16-2010, 02:50 PM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
you could always cut off the axles, seal it well, jack up the axle on one side and fill til you see oil. my guess would be about 2 1/2 gallons. you dont care about it being too full since the oil will never get hot enough to expand. then cap it and set it back down. the axle bearings will be 3/4 covered. will be just like an oil bath axle.
Old 05-16-2010, 06:42 PM
This thing is now relegated to being pulled by a tractor, maybe 3-4 miles at a time, maximum speed might be 20 mph.... it's not going to take a heck of a lot to lube the bearings to keep them going.
Old 05-16-2010, 07:14 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.RCrawler is gaining momentum as a positive member of FTE.
Once you get the oil up to level, jack up one side and then the other as high as you can get it. Then refill the diff.
If you're worried about it beyond that. Tear it down and grease pack the bearings.
Jason
Old 05-16-2010, 07:33 PM
i took a plastic plug and put in the axle tube made a steel outer caps for each side.
then drilled and taped a fill plug on each side then it only took a quart of oil for both sides
1959 Ford P350 axle ratios Lahti35 1957 - 1960 F100 & Larger F-Series Trucks 11 08-03-2016 11:00 PM
Wanting to swap rear axle on '77 F250 crazytrain77 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-28-2014 02:05 PM
Excursion Front Axle Info 3KIDDAD Excursion - King of SUVs 11 09-17-2012 08:03 PM
1990 Ford F150 Rear differential rebuild or replace? Superduty.pride 1987 - 1996 F150 & Larger F-Series Trucks 10 09-10-2011 12:10 AM
Superduty axle swap v10kev Clutch, Transmission, Differential, Axle & Transfer Case 3 11-11-2010 07:13 PM
Tags
1989, 2008, axle, axles, bearing, cap, dually, duty, end, f250, f350, ford, grease, rear, super, superduty, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
