Wheel wobble 89 F150 4x4 - Ford Truck Enthusiasts Forums
Old 05-15-2010, 03:22 AM
jessemace57 jessemace57 is offline
jessemace57 is starting off with a positive reputation.
I have a short wheel base 89 F150 4x4 with a 351 4" suspension lift and 33"x12.50" tires. Here lately when I hit the brake I get wheel wobble really bad, it also happens sometimes when I hit a bump. I am trying to find out what could be causing this. Lower ball joints are new. Any info would be much appreciated. Also I don't see a steering stabilizer under my truck. Is that normal?
Old 05-15-2010, 07:40 AM
KevinGnWV's Avatar
KevinGnWV KevinGnWV is offline
The village idiot.
KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.
Are you feeling the vibration in the brake pedal or steering wheel?
I would check lugnuts, make sure wheel is tight and centered properly. Aluminum wheels can come loose on their own sometimes. Check your wheel bearings, tierod ends etc.
If you feel a definate pounding in the brake pedal you have a warped brake rotor.
Old 05-15-2010, 08:47 AM
95F350XL 95F350XL is offline
95F350XL has a good reputation on FTE.95F350XL has a good reputation on FTE.95F350XL has a good reputation on FTE.
If you brake and it wobbles your rotors are def warped, if you are hitting bumps and you get the "death wobble" you might want to look into a dual steering stabilizer.
Old 05-15-2010, 11:43 AM
I feel it in the steering wheel deffinately. I stick my head out of the window and the drivers side tire is shaking side to side like speed wobbling as if it were a cheap crotch rocket. How do I install a stabilizer if mine doesn't have one? Also the inner tie rod bushing doesn't look so hot but both tie rod ends and ball joints look good. Could the inner tie rod bushing where it meets the centerlink cause all that? Thank you all so much for your help and input.
Old 05-15-2010, 11:45 AM
F-350 Mud Digger's Avatar
F-350 Mud Digger F-350 Mud Digger is offline
F-350 Mud Digger is starting off with a positive reputation.
Check the ball joints n tie rods. N make sure if you have aluminum rims that you have acorn lug nuts to sit properly n hold it on. Steel wheel lugs will make a aluminum wheel wobble till it will eventually fall off.
Old 05-15-2010, 11:54 AM
I have aluminum rims but I have the lugs with the sleeves so they go between my rim and stud with an accorn head.
Old 06-04-2010, 07:57 PM
F150-4-Life's Avatar
F150-4-Life F150-4-Life is offline
F150-4-Life is starting off with a positive reputation.
Jack up the tire...and grab the tire move it left and right and then up and down...make sure its not your bearings...
79'F150 4x4 wheel wobble ford4her 1973 - 1979 F-100 & Larger F-Series Trucks 15 01-03-2014 04:52 PM
Front end wobble Hoots250D 1999 to 2016 Super Duty 2 08-26-2012 05:29 PM
Major wobble in front end birddog55 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-22-2011 01:57 AM
Squeaking disc brakes LT/PM 1997 - 2003 F150 1 04-15-2010 06:14 PM
Front end wobble tuffguy 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-10-2001 11:59 PM
Tags
89, ball, bump, check, f150, f350, ford, hit, truck, uoints, wheel, wheels, wobble, wobbling, wobbly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
