Return Caps Rev. 1.0
Old 10-14-2010, 10:26 PM
mechelement's Avatar
mechelement
mechelement is offline
They've finally arrived...
Sorry about the poor quality Samsung P&S pics... The caps turned out quite well. Revision 1.0 is a material change to brass. After I showed him the last round of backyard TIG welding, my dad decided to change materials and silver solder them himself. I couldn't get the flux off with the non-abrasive scotch brite pads I have.
Old 10-14-2010, 10:34 PM
GenLightening's Avatar
GenLightening
GenLightening is offline
Nice work! I might have to try that sometime.
Old 10-14-2010, 11:46 PM
87crewdually's Avatar
87crewdually
87crewdually is offline
I was wondering what happen with the follow up. Nice proto-types. Do you have some Viton #111 o-rings (16) to try them out? They appear pretty thick in the wall, he could probable turn the O.D. down some to save bulkiness which may cause premature o-ring failure from vibration. Keep us updated and see if he's willing to make sets for resale after some testing.
Old 10-14-2010, 11:55 PM
wreckinball's Avatar
wreckinball
wreckinball is offline
holy friggin awesome! i dont have a problem with the plastic caps but hey if its one thing i never have to replace ever again, i am in!! Sweet man, congrats!
Old 10-15-2010, 06:59 AM
mechelement
Yep, 42 viton o-rings left for testing these.
The barbs sit inside a tight clearance hole and the solder runs in after heating creating an air/water tight seal. That's the reason for the thickness. I suppose he could've stepped it down a bit away from the barb holes.
I thought he was going to fin these like he did the aluminum, but he was in a hurry due to all the other work he has. He wants to know if they work or not. He's actually making another few aluminum ones and experimenting with brazing/soldering aluminum. If he can do it, he'll send me a complete set of aluminum caps too.
Old 10-15-2010, 07:15 AM
greywynd's Avatar
greywynd
greywynd is offline
Most silver solder fluxes will wash off with hot (really hot) water. A coat of cleat lacquer will keep them from tarnishing in time too.
Old 10-15-2010, 08:11 AM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
They look sweet, my concern is heat ...
I would ensure your return line routing leaves no dead headed ends ...
-Enjoy
fh : )_~
Old 10-15-2010, 11:39 AM
rodneywar's Avatar
rodneywar
rodneywar is offline
use the n/a setup for all motors i hate dead headsjust leav long enough hose to let it sit under the turbo if you have one or get viton lines they are pretty resistant to heat
Old 10-15-2010, 12:22 PM
Festus Hagen
Methanoholic
Not all the N/A return layouts are the same ... It's specific to the 7.3 N/A.
Basically, it goes from the Filter through the right bank to the Tee at the back of the motor, and from the IP through the left bank to the Tee at the back of the motor ...
-Enjoy
fh : )_~
Old 10-15-2010, 12:32 PM
rodneywar's Avatar
rodneywar
sorry festus i should have been more specific
Old 11-21-2010, 01:56 PM
mechelement
Success
Got them installed yesterday after doing the valve cover gaskets, retorquing the rocker bolts, installing new glowplugs & injectors.
No leaks so far. We used the average tolerance between all plastic caps. Installing these was a bit more difficult because they're not plastic and don't give at all when pushing them over the o-rings. So you don't get that snap, but they've been machined so when the fuel lines are tightened, the caps will seat properly. I actually gave them a few taps with a very small brass hammer. You're able to turn them by hand when they're installed. I have not measured their temperature since running them.
Old 11-21-2010, 02:25 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
very nice!
your going to get a few pms i bet now,with people begging you to make them a set.
Old 11-21-2010, 03:09 PM
oreocreaming's Avatar
oreocreaming
oreocreaming is offline
damn, cant believe i missed this post. i think it was when i was heading to boston. those look bad a$$ man. cant wait for them to be proven and you start selling them maybe your dad can make me the 2nd set and send them when he quotes you on those pto extender coolers
Old 11-21-2010, 07:17 PM
FL-Mudd-Duck's Avatar
FL-Mudd-Duck
FL-Mudd-Duck is offline
i want 2 sets 1 n/a 1 for turbo
Old 11-21-2010, 07:27 PM
oreocreaming
tell your dad we can keep him busy over his thanksgiving and christmas vacation lol
Quick Reply: Return Caps Rev. 1.0
