Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 05-14-2010, 09:35 PM
quichr38 quichr38 is offline
Garage is empty, add now
quichr38 is starting off with a positive reputation.
86 F150 Clutch Slave Cylinder Replacement
Just picked up a 86 f150 and second day driving it the clutch slave cylinder went out. Never had to replace one of these before and just looking for a little guidance. Any help would be great. Thanks. If anyone knows of an online instruction for this replacement that would be nice as well.
I love this truck and want to get it up and running ASAP.
edit: it is a 4x4 4speed with the 302 in it. The slave cylinder is external
thanks!
  #2 (permalink)
Old 05-14-2010, 10:40 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
1989 Ford F-250
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
Pry the old on off the bellhousing, and bring it out under the truck so you can work on it. I have never had to take the line off yet, but I believe someone said there is a keeper pin that holds the line in place, and it has to be driven out.
Once you get the new one on, I would look for a bleeder. Some are obvious, and some are a 5/32 allen screw hiding on the slave. Open the bleeder and see if you can get some air out of it. Not all the air will come out though. Re-install it, and then push on the clutch pedal to break the wire tye holders that came on it. Keep an eye on the clutch master fluid level. Pump it a few times and see if you can get the tranny in gear. If you can force it in gear, drive it around, and as you drive it, the air that's left in the system will make it's way up the line and into the master reservoir.
__________________
Dave F
1989 F250 XLT Diesel
Tags
1980, 1986, bleeder, bolt, clutch, cluth, cyl, cylinder, f150, ford, master, replace, slave, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
