Go Back   Ford Truck Enthusiasts Forums > Misc. > Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Sign in using an external account
Register Forgot Password?
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.SPONSORED BY:
Click Here
  #31 (permalink)
Old 02-25-2012, 07:39 PM
cford716 cford716 is offline
Garage is empty, add now
cford716 is starting off with a positive reputation.
Quote:
Originally Posted by onug View Post
I don't think the corners will start to warp up, these things are pretty solid. My SE is held on by four "C" clamps (like those used to hold on canopies) in the middle and then the locking mechanism at each corner. I've never seen an HD model, but I'd guess it is held on in a similar fashion.
The Line-X treatment is the way too go. I love being able to throw stuff up on my cover or shove it around in my garage (when I take it off) and not worry about the surface. If mine has any dents or scratches, they're blending in nicely because I can't see them.
As for freezing, the cover will freeze to the rails when it gets cold. I've got a gnarly ice scraper and use it to pry the cover open during the morning "Ice Scraping" olympics. It usually opens easily.
The cover isn't perfect by any means, but it's held up great for me. If I was to do it over, the only thing I'd change is to get the HD model.
I agree with everything except that the only time I have seen it freeze is if its raining and then the temp drops. I live in buffalo, and have not had any trouble with freezing from snow.
I also say go with the Line-X. Tough stuff and I also didn't want to be polishing. I would have liked to have gone with the HD but couldn't justify the cost, the SE is all I have need for. I also would have gotten the cab guard, that will be my next purchase.
Do not regret this purchase, highly recommend it. Especially if you want to be able to carry something on top.
  #32 (permalink)
Old 02-27-2012, 12:30 PM
tikka tikka is offline
tikka is starting off with a positive reputation.
I wonder is applying wax or a silicon (stay put) product on the seals might keep them from freezing together. SOmething that wouldn't degrade the seal material.
So it is the seals freezing?
  #33 (permalink)
Old 02-27-2012, 12:32 PM
How do you ice scrape the seals.. ? Are they exposed when the top is down?
  #34 (permalink)
Old 02-27-2012, 10:59 PM
onug's Avatar
onug onug is online now
2010 Ford F-350
onug is starting off with a positive reputation.
The freezing happens between the seals and the plastic rail covers on the truck. I don't scrape the seals, I just use the scraper as a pry bar to pop the back open.
__________________
2010 F-350 Lariat: Crew cab, long box, 4x4, V10, 4.10 rear, nav, snow plow prep, aux switches, sun roof.
Accessories: Line-X, DiamondBack tonneau cover, ProClip cell mount, Fumoto drain valve, Maglite mount on B-pillar, WeatherTech Mats, K&N drop-in air filter, PIAA Xtra Xtreme headlight bulbs, ScanGauge II
Toys: 2009 Arctic Fox 26Z-2 Travel Trailer
  #35 (permalink)
Old 02-28-2012, 09:40 AM
I would think most of the designs have this problem. I was wondering if one of the rubber/tire products would reduce the freezing gluing action from happening. Something like ArmorAll or a wipe with WD-40. In the past on my doors I applied Armorall throughout the summer - nothing in the winter and no frozen doors (seal to frame). I reduced my applications in the summer time to about "0" and now I have my doors freezing..... (on the old truck). I need to get back to applying the product - seems to keep freezing to a minimum.
  #36 (permalink)
Old 02-28-2012, 10:44 AM
onug's Avatar
2010 Ford F-350
That's an interesting idea and it sounds reasonable. I might try it if I get a chance this season
  #37 (permalink)
Old 02-29-2012, 02:44 PM
MDSuperDuty's Avatar
MDSuperDuty MDSuperDuty is offline
MDSuperDuty is gaining momentum as a positive member of FTE.MDSuperDuty is gaining momentum as a positive member of FTE.
Had the HD cover on the previous truck and sold it. I actually miss that cover, very versatile and so easy to remove and put on. This Leer cap that came with my current truck looks nice but leaks much more than the diamondback ever did. Mine only leaked from the front corners of the bed where the plastic bed rails and front bed rail met and left a hole the size of a pencil eraser. Other than that dry as a bone. The Leer cap leaks in at least 4 places (3 in the roof, 1 window seal) but it is probably 4-5 years old.
__________________
2008 F350 CC, DRW, SWB, V10, 4x4 LEER Cap.
2002 Taurus (THE WINTER BEATER!!!)
2006 F250 Ext Cab, LWB, 5.4V8, 4x4 (traded 07/11)
2005 F150 Ext Cab, SWB, 5.4V8, 4x4 (traded 01/08)
1996 F150 Ext Cab, SWB, 4.9 I6, 5spd, 4x2 (Sold) This truck started it all!
  #38 (permalink)
Old 02-29-2012, 03:03 PM
Quote:
I am struggling with the decision to buy a diamondback. I have always had caps on my toyota trucks. I know it looks like a great product, but can I live with it...... what the hell I guess....
  #39 (permalink)
Old 02-29-2012, 04:16 PM
Quote:
Worth every penny in my opinion. I looked at fiberglass lids, UnderCover, Pace Edwards Roll Up, BakFlip, etc...... This just seemed unbreakable compared to the others, the HD version that is.
__________________
  #40 (permalink)
Old 03-15-2012, 04:59 PM
I was in the same position you are. I had always had caps, but only really needed it once a year for a vacation and I didn't like the looks of them as much as just a cover. I solved my vacation problem with the Diamondback because I put a car carrier on top of it for the extra room I need. Otherwise I normally leave it on and can quickly take just half off or the whole thing depending what I need.
  #41 (permalink)
Old 03-15-2012, 09:41 PM
Quote:
Well ordered one early in the week. They had the lineX in stock for the RAPTOR. Will keep you posted. I agree with your thoughts. I like the idea I can stand on it if I need to without damaging it. With freight and taxes etc.. $2000.00
Tags
bed, compaired, cover, covers, damage, diamondback, f150, f350, ford, linex, model, parts, replacement, tonneau, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
