351w bellhousing number query
I've been offered a 351w bellhousing - part no. D1TA6394 AA (cast iron-not alloy)
I know these were used in early 70's Mustangs with 351W's & C's, but are they compatible with an NP435 in our era trucks? I don't have it to measure & compare.
Also, were they for mech. &/or hydraulic clutches?
Thanks
Thanks
ID engineering number: D1TA-6394-AA = Ford part number: D1TZ6392D (replaced D1TZ6392C & C5TZ6392A) .. Bellhousing / Obsolete
Fits: 1965/74 F100/350 & Econoline 240/300 I-6 / 1975/79 F100/350 & Econoline 300 I-6.
Fits; 1966/68 Bronco 289 / 1969/77 Bronco 302 / 1971/79 F100 302 / 1975/79 F150 302 / 1973/74 Econoline 302.
No hydraulic clutches until 1983 (6.9L diesel & 460) / Until 1984 w/300/302/351W.
While it may not have been intended to fit a 351W, it will, since the 240/300/302 shared the same bellhousing bolt pattern as the 351W/351C.
This is by no means a promise that it would work for your intended application, but I suspect it would accept the NP435, since it was a direct swap for the BW T98/T18, and all of those were found in various models using the aforementioned list of apps the bellhousing was originally used in.
Bill, I've since found another bellhousing - alloy, casting no. E4TA 7505 DA, which is 6 1/4" deep.
Will this be OK with an NP435/351W combination, in my 83? I'm converting from the original AOD trans.
If possible, I'd like to use mechanical clutch linkages to avoid firewall problems.
I understand my engine to have come from a 77 or 78 car.
Thanks again
Thanks again
niceshot979
02-15-2017 11:44 PM
fastredford
13
05-04-2010 08:33 PM
stats2me
11-04-2005 08:26 AM
