Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-13-2010, 10:18 PM
RebusCom's Avatar
RebusCom RebusCom is offline
Garage is empty, add now
RebusCom is starting off with a positive reputation.
Strange 460ci misfire problem
I have a 1989 E350 with 460ci engine & C6 trans. It runs fine unless the parking lights or headlights are turned on. With lights on two cylinders drop out. If I give it lots of gas one of them will kick back in leaving one cylinder misfiring but back to cruise and two cylinders die. With lights off all cylinders run all the time. BTW, this van has quite a few marker lights so the light draw is somewhat higher than most vans.
I checked voltage at the "downstream" side of the main accessory breaker (mounted on chassis near battery) to ground with engine running it holds a constant 13.8v with lights on or off. With the engine off it measures 12.8v with lights off and 12.4v with lights on.
  #2 (permalink)
Old 05-13-2010, 11:19 PM
tinaheels's Avatar
tinaheels tinaheels is offline
tinaheels is starting off with a positive reputation.
c9 tranny ? really i think u mean a c-6 trans
  #3 (permalink)
Old 05-24-2010, 03:13 PM
wizzy214's Avatar
wizzy214 wizzy214 is offline
1999 Ford E-Series Van
wizzy214 is starting off with a positive reputation.
post this in the 67-newer econolines
  #4 (permalink)
Old 05-24-2010, 07:06 PM
RebusCom's Avatar
Quote:
I did over a week ago.
http://www.ford-trucks.com/forums/95...lights-on.html
So far nobody has any suggestions.
  #5 (permalink)
Old 05-24-2010, 07:52 PM
dustybumpers's Avatar
dustybumpers dustybumpers is online now
Almost Normal
1995 Ford F-150
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
check all grounds and clean them. especially the ones from the frame to the body that just clip on. you are robbing the grounds from the ign with your lights
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Quote:
Originally Posted by 67nukeford View Post
Charlie, don't make me come there and kill you...
"If more sane people were armed, the crazy people would get off fewer shots."
Tags
1989, 385, 460, 460ci, ci, e350, f250, ford, misfire, missfire, series, set, specs, superduty, timing, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
