Ball Joint replacement price
I have been told anywhere from $1,200-$1,500.
I strongly suggest you do it yourself if you have any wrench-turning ability. It is really quite simple and easy to do yourself.
You can get the moog kit online (includes everything you need) for around $350.00, and a pair of new Timpken unit bearings for $450.00.
It will probably take you about 2 hours or less to take it all apart.
It will take about 45 minutes to remove/replace the ball joints.
It will take about 2 hours if you want to rebuild your autohubs.
It will take about 25 minutes to make your own outer seal installation tool, and then another 30 minutes to "press" on the 2 new seals.
It will then take about 1 1/2 hours to re-install the knuckles, hubs and bolt everything back into place.
If you need brakes, do them at this time also.
For under $900, you can perform all this maintenance work, worth more than $3,000 at the dealership, in 1 hard day or an easy weekend.
I just did all this work myself 10 days ago, including new rotors/brakes on all 4 corners. ($350 more)
Here is a couple of links to help you decide if you are up for a DIY.
2004 F250 Ball Joint Replacement
Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
clhart426
18
01-19-2021 09:46 AM
