Rear axle clunking noise when turning - Ford Truck Enthusiasts Forums
Old 05-13-2010, 08:30 AM
bthacker bthacker is offline
bthacker is starting off with a positive reputation.
Hi,
I have a 2004 F-150 Lariat (2WD) with the limited slip differential. About two years ago I experienced the well-known shuddering sound when turning. I had the problem corrected at the dealer.
About a month ago I noticed a faint clunking sound coming from the rear end. It happens only when turning. I pulled the wheels and found about 1/16" of play when I push/pull on the hub. The axle seals are not leaking, and it happens on both sides, so it appears to me that the problem is in the differential.
Has anyone experienced this problem, and if so, could you give me some advice or recommendations as to how to proceed in correcting the problem?
Thanks in advance.
Front left axle shaft play Nicmike Excursion - King of SUVs 46 10-15-2015 05:07 PM
Scary clunk in drivetrain DBreedlove 1999 to 2016 Super Duty 24 04-07-2014 10:49 AM
99 Ford Ranger Supercab 4X4 driveshaft Thump/Clunk problem nothingbutford46 Ranger & B-Series 8 06-14-2013 10:04 PM
Rear wobble Spiritof'76 1997-2006 Expedition & Navigator 5 03-14-2010 05:43 PM
clunking/popping noise from front axle? 95f150 1987 - 1996 F150 & Larger F-Series Trucks 14 03-10-2004 07:01 PM
Tags
2004, 2005, 4x4, bronco, clunk, clunking, end, escape, f150, ford, forum, noise, rear, turning, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
