2005 f150 2wd rear disc brake rotor removal
I am wanting to swap out the stock rotors and pads for a set of cross drilled and slotted rotors and ebc green stuff 600 series pads. The problem is I can't get the old rotors off! I have unbolted the calipers and removed them and placed them on the leaf spring. Undid the parking break cable off both sides to relieve the PB and beat all around the rotor with a hammer and the rotors are not budging! Any help would be great.
If you are able to rotate the rotor it is not the handbrake binding, if it is sticking you can find a rubber bung at the 6 oclock position in the backplate, behind you are able to flick the adjuster for the handbrake, it works both ways so by mistake you could be flicking it the wrong way which will lock the rotor completely.
If you feel the hand brake is not at fault it is rusted between the half shaft with the wheel lugs (studs) on it and the rorotr itself, dose it in diesel or WD40 and leave overnight, smacking it will buckle it so be careful.
i had the same dliema.... i was lucky i just put new pads ,but this fall i WILL be taking the old rotors off... if your lucky enough to live in a snowy area (im in central ontario) the rotors will be a bitch... heat the buggers up and beat them... like i said... i never got mine off... but i also only had a small propane torch.... next time i will be heating them up with oxy/acl, or worse case scenario... cutting them.....
I saw this posted a while back. Looks like an easy/painless way to remove rotors.
YouTube - Remove Rusted Ford Truck / Expedition Brake Rotors
Anyone ever use the caliper to push the rotor off? I just tried it and it works great.
I have seen the video posted above, but the rear brackets and bolts on my truck are different(It would require a 1/4" or so bolt, and I was not replacing my disk)
I just removed the outer brake pad, then removed the slide pins and boots. Then I bolted the caliper back on with a 5/8 socket as a spacer in between the caliper and the bolt. Then I hit the brake pedal and POP it was free.
OJs DNA
1999 to 2016 Super Duty
01-07-2022 08:11 AM
joshofalltrades
03-05-2013 01:39 AM
95F150SuperCab
22
08-26-2010 03:50 PM
