Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
  #1 (permalink)
Old 05-13-2010, 08:13 AM
choochoof150's Avatar
choochoof150 choochoof150 is offline
1995 Ford F-150
choochoof150 is starting off with a positive reputation.
2005 f150 2wd rear disc brake rotor removal
I am wanting to swap out the stock rotors and pads for a set of cross drilled and slotted rotors and ebc green stuff 600 series pads. The problem is I can't get the old rotors off! I have unbolted the calipers and removed them and placed them on the leaf spring. Undid the parking break cable off both sides to relieve the PB and beat all around the rotor with a hammer and the rotors are not budging! Any help would be great.
  #2 (permalink)
Old 05-13-2010, 09:40 AM
slomafarms slomafarms is offline
2001 Ford F-150
slomafarms is starting off with a positive reputation.
heat it up and pound on it
__________________
01 f150 fx4 5.4 scab fx4 144,000mi
  #3 (permalink)
Old 05-13-2010, 10:59 AM
nickstrathford nickstrathford is offline
Garage is empty, add now
nickstrathford is starting off with a positive reputation.
brakes
Did mine last fall and it just takes a bit of pounding. They will just pop off in no time
  #4 (permalink)
Old 05-13-2010, 01:12 PM
2001 Ford F-150
my dad just all of his on his 04 screw 4x4 and all came off with ease. they were all orig rotors
__________________
  #5 (permalink)
Old 05-13-2010, 04:27 PM
compsec compsec is offline
compsec is starting off with a positive reputation.
If you are able to rotate the rotor it is not the handbrake binding, if it is sticking you can find a rubber bung at the 6 oclock position in the backplate, behind you are able to flick the adjuster for the handbrake, it works both ways so by mistake you could be flicking it the wrong way which will lock the rotor completely.
If you feel the hand brake is not at fault it is rusted between the half shaft with the wheel lugs (studs) on it and the rorotr itself, dose it in diesel or WD40 and leave overnight, smacking it will buckle it so be careful.
__________________
He who dies with the most toys WINS !!!!!!!
  #6 (permalink)
Old 05-14-2010, 08:41 AM
rkedz rkedz is offline
rkedz is starting off with a positive reputation.
Use a bigger hammer...........
  #7 (permalink)
Old 05-14-2010, 08:47 AM
jr105 jr105 is offline
jr105 is starting off with a positive reputation.
I've found spraying a good penetrating oil (I like PB Blaster) on it and hammering away has worked for me. It may take more than one application of the oil.
  #8 (permalink)
Old 05-14-2010, 11:45 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
if it just refuses to come off, visit your local parts store. most rent out special tools for free...or just a few bucks.
get a slide hammer. use the hook attachment and knock that puppy off there.
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #9 (permalink)
Old 05-16-2010, 12:40 AM
lilmustangboy's Avatar
lilmustangboy lilmustangboy is offline
lilmustangboy is starting off with a positive reputation.
i had the same dliema.... i was lucky i just put new pads ,but this fall i WILL be taking the old rotors off... if your lucky enough to live in a snowy area (im in central ontario) the rotors will be a bitch... heat the buggers up and beat them... like i said... i never got mine off... but i also only had a small propane torch.... next time i will be heating them up with oxy/acl, or worse case scenario... cutting them.....
__________________
2006 F150: 4.2L V6, auto tranny, 3.55 Limited Slip, A/C, Cloth Bench, ACI LiteRider Tonneau Cover
Up for sale soon to buy a :family car"
  #10 (permalink)
Old 05-16-2010, 05:04 AM
svt2205 svt2205 is offline
svt2205 is gaining momentum as a positive member of FTE.svt2205 is gaining momentum as a positive member of FTE.
I saw this posted a while back. Looks like an easy/painless way to remove rotors.
YouTube - Remove Rusted Ford Truck / Expedition Brake Rotors
__________________
2011 FX4
  #11 (permalink)
Old 05-16-2010, 04:53 PM
1995 Ford F-150
I finaly got it. They were just a very tight fit around the center hub.
  #12 (permalink)
Old 11-04-2010, 11:46 AM
alument alument is offline
alument is starting off with a positive reputation.
Anyone ever use the caliper to push the rotor off? I just tried it and it works great.
I have seen the video posted above, but the rear brackets and bolts on my truck are different(It would require a 1/4" or so bolt, and I was not replacing my disk)
I just removed the outer brake pad, then removed the slide pins and boots. Then I bolted the caliper back on with a 5/8 socket as a spacer in between the caliper and the bolt. Then I hit the brake pedal and POP it was free.
  #13 (permalink)
Old 01-01-2011, 03:30 PM
Carmel_Bill Carmel_Bill is offline
Carmel_Bill is starting off with a positive reputation.
Smile
Thanks for posting this method for removing rear rotors. Worked like a charm and made for easy work.
Tags
2004, 2005, 2006, 2wd, brake, cross, drilled, f150, ford, pad, rear, removal, rotor, rotors, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
