Power window switches don't work. - Ford Truck Enthusiasts Forums
Old 05-12-2010, 06:53 PM
Explorer Freak's Avatar
Explorer Freak Explorer Freak is offline
Explorer Freak is starting off with a positive reputation.
The front pass. side door and both rear door power window switches don't work on my '99 Explorer. All the windows go up and down just fine when using the driver's door switches. Also, the pwr. locks button on the front pass. door doesn't work. It will lock, but won't unlock.
Is there a fuse that's blown or is this something more complicated?
Old 05-12-2010, 06:59 PM
mwkobe mwkobe is offline
mwkobe is starting off with a positive reputation.
main switch on driver side most likely bad it has that switch in it that disables the others and that switch fails in the disable mode
wayne
Old 05-12-2010, 09:24 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Since you are also experiencing issues with the power locks, and assume they work fine from the other lock switches, I'm guessing you have a broken wire or more in the multi-pin connector between the door and cabin in the door jamb. That's a pretty common problem.
-Rod
Old 05-15-2010, 02:15 PM
Thanks guys!
Old 07-24-2010, 09:42 PM
Dixiesweep Dixiesweep is offline
Dixiesweep is starting off with a positive reputation.
didnt know the drivers side controlled the passenger side. My driver window works fine..but, the passenger window will not go up or down sometimes. By the way..both window motors have been replaced over the last month.
Old 07-25-2010, 02:25 PM
shorod's Avatar
Quote:
What year is your Explorer? Does the passenger window work reliably with the switch on the passenger door, just not the driver's door, or does it just not work reliably, regardless of which switch you use?
-Rod
Old 07-25-2010, 09:12 PM
power windows
I figured it out today. I traced the power from the main switch and found that i had power to the passenger door. Then traced it from the switch to the motor. Had power all the way. Took a small body hammer and tapped the motor..and away it went. I just replaced both front window motors last week. If it does it again..i am returning the motor.. Thanks for the reply....Joe
Old 07-25-2010, 11:16 PM
shorod's Avatar
Interesting. Here's to hoping the hammer tap is a long term fix. Out of curiosity, did you replace the motors for this issue, ie: was the old motor functioning the same way? If so, I'd be very surprised if you hammer tap turns out to be a long-term fix.
-Rod
Old 07-25-2010, 11:33 PM
power windows
No it wasnt working at all. I replaced them because the truck is a 91 and it was the original window motors. I am plaaning on keeping the truck so i wanted to make sure at least the windows would work. lol
2003 Explorer RMeans Explorer, Sport Trac, Mountaineer & Aviator 6 05-03-2016 10:34 PM
Part number eluding me reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 04-26-2014 12:06 AM
2002 Explorer Power Window Problems - HELP Jeff Hildreth 1997-2006 Expedition & Navigator 7 07-08-2013 08:33 PM
power windows and door locks don't work boogaloo 1978 - 1996 Big Bronco 8 03-06-2011 01:35 PM
Power Window issue... o2civic 2004 - 2008 F150 7 10-21-2008 12:04 PM
Tags
2001, 2005, consistently, dont, expedition, explorer, ford, locks, mountaineer, power, switches, truck, window, windows, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
