No radio or windscreen wipers
Hi all.
Have an issue with no ignition power to my radio or windscreen wipers. Have tested and inspected fuses, all ok. Tested fuses at cab fuse box and no voltage to these fuses. Is this related to the accessory delay relay and battery saver relay? Also read it may be the accessory relay? Does anyone know where this is located?
Cheers
Luke
Cheers
Luke
I'm starting to lean towards the ignition barrel or something in the wiring there? Testing the points on the accessory delay relay and it has power at the same contact points with the key on accessory and when running.
From what I've readand looking at the wiring diagrams I have/can find if it was the battery saver relay or accessory delay relay it wouldn't work in either position.
I think you are on the right track, I wouls suspect some break or short somewhere in the column as you were parking when it died, the wiring in there is not particularly robust.
I have some 2002 model electrical schematics as PDF files if you want them PM me your email address and I will send you copies.
Best of luck mate, I hate chasing vehicle wiring gremlins, they are always in difficult to get at places, laying upside down head under the dash.
Murphy is a *******!
budlightman11j
07-31-2013 07:52 PM
Diesel 724
11-01-2010 12:16 PM
wgm5286
08-04-2007 02:52 PM
Shepard
Electrical Systems/Wiring
07-18-2006 12:27 PM
