Who makes this posi unit?? - Ford Truck Enthusiasts Forums
Old 05-12-2010, 03:48 PM
lizardman1's Avatar
lizardman1 lizardman1 is offline
lizardman1 is starting off with a positive reputation.
This was described to me as a Eaton TrueTrack. It is not that at all. Is this unit as good??
Old 05-12-2010, 07:29 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
That looks more like a spool than a diff, except for the gears. Maybe some kind of one legger? I found this, Ford 9 Inch Rear Truetrac Posi LSD Limited Slip 28 Spline [TT 912A587] - $499.00 : JTs Parts & Accessories, Justdifferentials.com The picture looks close and calls it a true trac.
Then there is this page Ford 9-inch Axle - Off-Road Magazine The true trac looks right again. This is all assuming you are working with a 9".
Old 05-12-2010, 09:09 PM
lizardman1's Avatar
Just found out it is an Eaton True Track, fits Ford 9" and does not look anything like the generic pics online. Shocking!! As for the manufacturers shame on them, there needs to be an accurate pictoral representation as per aplication just my 2C worth. Thanks for the response.
Old 05-12-2010, 09:20 PM
ReAX's Avatar
the bigger case design probably is the same for the C-clip axles like the 8.8 and Corporates. So the picture probably covers most fords and all chevy's, who knows about dodge. Just the 9" is different because the axles get bolted to the flange.
Old 05-13-2010, 09:56 AM
lizardman1's Avatar
I found out it is a True Track. it looked different from the others I have seen because the others were for other applications. Thanks for the help.
Ford Traction-Lok vs Eaton/Detroit eco Clutch, Transmission, Differential, Axle & Transfer Case 3 04-03-2007 06:34 AM
Buying Eaton ELocker 300-6 AUTO TECH Clutch, Transmission, Differential, Axle & Transfer Case 2 03-01-2007 07:15 PM
Eaton m112 blower - what oil? Scopie Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 1 01-24-2005 11:21 PM
Dash Lights will not work with headlights on... whaynes 1987 - 1996 F150 & Larger F-Series Trucks 4 07-30-2002 01:57 AM
Eaton Transmissions? Derek S 1999 to 2016 Super Duty 1 12-26-1999 07:53 PM
Tags
1972, 2009, 2wd, 9, aftermarket, f100, f150, ford, inch, posi, ranger, trucks, type, unit, units
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
