91 f150 tranny problems
Old 05-11-2010, 04:06 PM
the misk's Avatar
the misk
the misk is offline
have a 91 f150 4.9 I6 4 speed manual with an over drive. the other day i lost 1st and 2nd. 3rd 4th od and rev. still work fine ay ideas or thoughts.
Old 05-12-2010, 09:29 AM
jas88's Avatar
jas88
jas88 is offline
Do you mean the trans will not shift into those gears, or do you mean when you shift into them it's like it's in neutral?
Old 05-12-2010, 09:43 AM
the misk's Avatar
the misk
the misk is offline
it feels like it is in first or second but when you let the clutch feels like its in neutral
Old 05-12-2010, 01:09 PM
jas88's Avatar
jas88
jas88 is offline
Does it make any noise when you do that?
Old 05-13-2010, 05:54 AM
the misk's Avatar
the misk
the misk is offline
none thats why im not sure if the whole tranny is dead or if it is a problem with the shifter or the shift tongs themselves maybee
Old 05-13-2010, 09:17 AM
jas88's Avatar
jas88
jas88 is offline
The best thing you can do is remove the shifter and pull the carpet back which will reveal a big inspection plate bolted to the floor. Take that off, and there is your trans. The M5OD has a big top cover that you can remove and then you can see all the gears and such. Be sure it is in neutral when you remove the top cover, BTW. This will allow you to inspect the gears and also the shift forks.
The most common failure in these transmissions is the shift pins which are in the top cover where the shifter goes in. However, your problem does not sound like that.
Old 05-13-2010, 09:39 AM
andym's Avatar
andym
andym is offline
It sounds like worn-out forks to me. Do you rest your hand on the shifter when you drive it? Pulling the top cover will tell the tale.
BTW if it has five forward gears, it's a 5 speed.
Old 05-15-2010, 11:11 PM
the misk's Avatar
the misk
the misk is offline
ok so i will pull the cover and inspect. and post once i have look. i took the shifter out once allready and had a look at it but couldnt see much i must have to pull that access panel to have a better look. thx for the tips guys will get back when i know more.
giggles1855
02-21-2012 03:43 PM
matt0963
WTB - Parts & other
08-04-2011 04:06 AM
joelfx4
08-26-2010 12:49 PM
Cowboy34
06-21-2010 11:41 AM
burton
Computer Chips & Tuners
11-19-2000 10:26 AM
Quick Reply: 91 f150 tranny problems
