Vacuum issues, defroster is stuck on - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-11-2010, 03:54 PM
Pro DIY Pro DIY is offline
Pro DIY is starting off with a positive reputation.
So I know that I have a vacuum issues because no matter what I have the vent selecter set to air will only come out of the defroster. I also am pretty sure I know where the vacuum leak is. The rubber vacuum lines for the locking hubs are old and cracked and are actually not connected to the front axle. My question is if I cap off the auto locking hub lines will that stop the vacuum leak enough so that I can once again use the vent selector? Or is there something else that I can do. Let me know what you think.
Old 05-11-2010, 05:59 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Absolutely. Anything to stop the vacuum leak should allow the A/C accuator motors to work again
Old 05-16-2010, 04:00 PM
2kdually 2kdually is offline
2kdually is starting off with a positive reputation.
I'm not sure what year you have. My 2000 had the same problem. The vacuum pump and res. on the pass. side engine compartment builds up when you turn the key. My front hubs didn't work any longer and the vacuum would never build up. The defrost is the default position and the heater/ a/c needs the vacuum to actuate. I just plugged the ports that fed the hubs, and all is well.
2000 F-350 7.3l Crew cab dually
Old 05-17-2010, 10:14 AM
Mines a '99. Where did you plug them? At the point where it enters the wheel well or did you do it at the pump/res. And what did you use to plug them? Thanks for your time.
Old 05-17-2010, 03:08 PM
I plugged them at the pump/res. I'm not in front of the truck, and sorry, I don't recall what I used. But any "plug" that will stop the leak will work. I'm sure that most parts houses will have rubber fittings/sleeves that slip over a vacuum line connector that will work.
If you still need help tomorrow, I can revisit and see what I used.
Old 06-18-2010, 12:13 PM
6erwebb 6erwebb is offline
6erwebb is starting off with a positive reputation.
Hope im not stepping on any toes reviving this thread but Im having this problem as well however my truck is a two wheel drive. The hoses dont look bad, also upon initial start up sometimes the vents blow the ac but after while itll switch to defrost.
Any advice???
Old 06-18-2010, 01:02 PM
scottzj's Avatar
scottzj scottzj is offline
Hangin 10 bra
scottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud of
Sounds like a vacuum issue. The electric vacuum pump is known to go out and that could cause your problem. Below was posted awhile back from a fellow FTE, that might help you understand it.
Old 06-18-2010, 03:24 PM
is there any way to test the pump? I have a friend with a hand pump but wont be home til tomorrow.
Old 06-18-2010, 07:33 PM
sandmanf250 sandmanf250 is offline
sandmanf250 is gaining momentum as a positive member of FTE.
there is a tsb about a blend box sticking problem .(maybe)
stuck on defrost vacuum leak Fordsdad Excursion - King of SUVs 16 02-06-2015 02:38 PM
4x4 hubs not auto locking f250white 6.0L Power Stroke Diesel 1 01-23-2015 07:10 PM
2002 F350 Vacuum problem with Defrost and Hubs schaerem 1999 - 2003 7.3L Power Stroke Diesel 16 11-13-2014 01:09 PM
Blend door issues on 99 F-250 mizzitch 1999 to 2016 Super Duty 1 01-05-2014 09:03 AM
vents not working, vacuum questions LSO1123 1999 - 2003 7.3L Power Stroke Diesel 4 11-14-2011 05:33 PM
Tags
99, defrost, defroster, duty, excursion, expedition, f250, ford, heater, issues, problems, stuck, super, superduty, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
