airdog 2 - Ford Truck Enthusiasts Forums
airdog 2
Old 05-11-2010, 11:16 AM
pfk1616 pfk1616 is offline
pfk1616 is starting off with a positive reputation.
airdog 2
I have a 2005 f350 diesel I am running no cat or muffler, power pup, air raid air filter. Stock lift pump went bad. Which airdog would work well with my set up? What happens to the stock upper fuel filter if I install this set up? and where do I get just the upper filter if this set up remains
Old 05-11-2010, 11:25 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Basically the only thing that got bypassed on my ADII install was the high pressure fuel line going into and out of the HFCM. The fuel bowl and return line aren't touched. The ADII comes with a 2 micron filter (plus a water separator filter that's washable and resuable) and the secondary filter on the truck is 3 micron. If it's still good then just leave it alone. You can't buy it alone as it comes in the set, at least as far as I know. If you find a place to buy them separately then PLEASE let me know.
Old 05-11-2010, 01:16 PM
DSMMH's Avatar
DSMMH DSMMH is offline
DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.
Quote:
I just installed an AD2. My AD2 has an internal pressure regulator and an internal fuel return to the fuel tank. So here are the mods I did to my fuel system.
Since my AD2 has an internal presssure regulator, I had to neuter the OEM fuel pressure regulator. I removed the OEM spring and brass cup and reinstalled the cap.
Next I removed the return line fitting from the filter housing, drilled and tapped it for 1/4-20 threads about 1.5" down inside the fitting. Then I took a 1/4-20 set screw, put some Locktite on the threads and screwed it in. That sealed the return line. If this is NOT done, you will not have any fuel pressure to the motor.
Since the AD2 has a 2 micron filter, I removed the engine mounted 3 micron filter and the filter mounting stem. This MUST be done or the stem without a filter installed will shut off fuel to the motor. I figured why have another filter to increase fuel system pressure drop.
I then removed the Banjo Bolts (BB), removed and disgarded the check valve assemblies and drilled out all three holes to .200".
Using a fuel pressure gauge, I set may AD2 fuel pressure regulator to 70 psi.
Performance improvements after the AD2 and BB mods: lot better throttle response, more power when the go pedal is pushed and slightly better fuel mileage (16.2 to 17.1 hand calculated).
Remember, this procedure is for an AD2 w/ internal pressure regulator. If your AD2 does not have an internal pressure, you must retain the OEM fuel system.
Recommend, if you use the OEM system, that you install the new ford pressure regulator spring kit and do the BB mod.
DSMMH
Old 08-20-2014, 11:38 PM
Borden Borden is offline
Borden is starting off with a positive reputation.
My 2002 7.3 requires 60-70psi, Jason at Airdog says the new AD is set to 55 at the factory, I have mine turned all the way up and can only get 62psi so make sure you do not need more
FICM Replacement fluidp 6.0L Power Stroke Diesel 16 02-07-2016 12:17 PM
trading factory frame rail fuel filter for Airdog KR PowerStroke11 1999 to 2016 Super Duty 11 01-09-2014 12:35 PM
Twin filter setup like AirDog kjgibson2 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 10-03-2013 11:00 PM
Harpoon/hutch/FRX/Fuel bowl delete in one kit SSSimon Australia Chapter 12 08-09-2012 07:38 AM
CCV Delete Piolet 6.0L Power Stroke Diesel 8 08-08-2011 11:41 AM
Tags
1996, 2005, 60l, air, airdog, buy, dog, f250, filter, ford, fuel, ii, increase, pressure, psi, regulator, set, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
