Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Advertisement
  #1 (permalink)
Old 05-11-2010, 09:53 AM
Johnny Bravo 45 Johnny Bravo 45 is offline
Garage is empty, add now
Johnny Bravo 45 is starting off with a positive reputation.
Front Wheel Bearing assembly
I've a 2002 Ford F 250 superduty with a 5.4 v8, 4x4 crew cab.
I was 2hrs away from home when my front right wheel bearing went KaBoom. 1000$ later and a new front right wheel bearing assembly and brakes, I figured I need to replace the left wheel bearing assembly, however, the shop did not have access to a second wheel bearing assembly in a timely manner. I would have had them do the other side, but I needed to get home
So I've a few questions regarding the front wheel bearing assembly. I found a ton on ebay for less than 1/2 the price of less schwab. Ebay has many in the price range of 100-200. Less Schwab charged me 375$ for one I've done wheel bearings in the past, but never for the locking hubs for a 4x4 truck. The tech @ LS showed me a basic overview of how to do it and it seems pretty straight foward.
My main question is, DO I NEED TO PACK THE BEARINGS? from teh service manual, it does not reference the need to pack the front hub bearing assembly, but only to grease the axel.
Thanks for the help, you guyz Rock!
  #2 (permalink)
Old 05-11-2010, 10:15 AM
JEV JEV is offline
JEV is starting off with a positive reputation.
Main bearing is sealed so you can't really grease that one. The inner needle bearing that rides around the axle stub shaft can be greased. I usually use my finger and squeeze as much grease into it as I can.
__________________
2001 F-350 7.3L CC LB XLT 4X4
Stock exhaust straight piped, HPX, 6637 intake, CCV Mod, In tank prepump mods, Boost Pyro Tran Gauges, Overboost Reg., DP Tuner 60Tow, 80Econo, 120Race
1991 F-150 351W Extended cab, short box, Northland Edition, Detroit EZ locker.
2000 Excursion Limited 4X4 V10
  #3 (permalink)
Old 05-11-2010, 10:42 AM
MikeMcCasland's Avatar
MikeMcCasland MikeMcCasland is offline
MikeMcCasland is gaining momentum as a positive member of FTE.
A very good portion of this write-up will tell you exactly what you need to do.
2004 F250 Ball Joint Replacement
__________________
Mike - 2004 F-250 V10 CC FX4 SRW
  #4 (permalink)
Old 08-03-2010, 08:06 PM
jdross440 jdross440 is offline
jdross440 is starting off with a positive reputation.
Is the inner needle bearing replaceable? If so does anyone know a part number
  #5 (permalink)
Old 08-03-2010, 09:35 PM
nailed_nailer nailed_nailer is offline
nailed_nailer is starting off with a positive reputation.
On my 2000 F250 SD 4x4 v-10 SRW
The needle bearings are part #
Ford C6tz-3123-A
Napa B2110
I just replaced my drivers side Needle Bearing because I was replacing Ball Joints and had the hub pulled out.
I will be replacing a bad pass side Hub-Bearing assembly and Ball Joints next week.
I also replaced the tie-rod ends while I was under her.
New tires and an alignment after that. Hopefully get another 100k before I have to spend serious moneys.
329,000 and only relatively minor problems to date.
---Nailer---
Tags
2001, 4x4, bearing, bearings, ford, front, packing, replace, rotor, settings, sport, torque, trac, truck, trucks, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
