i got a 75 f250 it had a 460 but i got a built 390 and need to find the 390 tower and i haven't been able to find them jw if any one know were to get them thanks
they have to bolt to the frame cuz there is no cross member under the motor
??? All engine perches (towers as YOU call them) BOLT to the frame. The FE engine and Inline-6 engines share the same perches. However, one engine family uses the rear mount holes (FE) and the other (6 bangers) use the forward holes.
If you do indeed not have a crossmember under the engine you better get one before the frame flexes in and snaps.
