High Fuel Rail Pressure
04-27-2016, 06:36 PM
Do you have a monitor plugged into the USBII port?
04-27-2016, 06:39 PM
pull the codes is the first step and report back.
04-28-2016, 12:50 PM
on
Same issue
Quote:
Originally Posted by
CampSpringsJohn
P0088, but the dealership tested it and couldn't get it to reproduce
04-28-2016, 01:42 PM
Have them update the PCM. If the code comes back then you need a new HPFP.
The VCV (part of the HPFP) is having trouble controlling the amount of fuel.
There is a TSB on this, I don't have it right here. I might be in the tech folder though.
04-28-2016, 01:59 PM
on
Same issue
senix
Thank you, if I delete all of the def stuff and run a tuner will that make a difference?
04-28-2016, 02:08 PM
No. The HPFP is having an issue that needs resolved first.
04-29-2016, 11:48 PM
on
Mine is doing the same thing. Getting ready to replace the pump. Mine only does it with a load on it like having a loaded trailer hooked up. Easiest way to reproduce the problem is to put a load on it. If it throws the code again, time for a new pump.
Homebrewer29
6.7L Power Stroke Diesel
21
01-20-2024 08:00 PM
my50F1
32
08-13-2018 10:04 PM
NoelHannon
07-28-2017 05:35 AM
Amelio
05-26-2017 07:00 AM
KodiakF250
08-06-2016 08:27 PM
2008 ,
64 ,
code ,
diesel ,
f250 ,
ford ,
freestyle ,
fuel ,
high ,
location ,
p0088 ,
pressure ,
rail ,
sencer ,
sensor ,
v10
