I'm doing a brake job (rear, 10.5 axle) on my '99 F-250 and I'm looking for the torque specs for the following: spindle nut, axle bolts, caliper bolts, caliper bracket nuts, lugnuts. Thanks.
The clymer manual from autozone has that info... I just bought the three book Ford genuine set for my 01 F350... Nothing else really compares to the Ford manuals.
I heard that clymer and chilton manuals sometimes dont post accurate info. Not 100% sure though. I had heard that the torque setting on the spindle nut is 60 ft lbs then back off 7 clicks. on the axle bolts, I hear it is 80 ft lbs. Does this sound right?
