Wondering what model this is?
Saw this on my local craig's list page and have not seen this model Ford before. Anyone know what it is. For a $1000 I might just buy it for the way it looks, kinda cool in a different way.
ford dump truck / flatbed trailer/backhoe
She usually posts in the 1961/66 forum, has pics in her gallery
You have located a "very strong dump truck" !!! From what little I know, right now, people who have owned and worked them say "They were the mule of Ford's mid-range trucks and you couldn't break them" !!! I just purchased a solid "1966 Ford N-300 Dump Truck" with a strong engine VIN# N60CU412339 (With A Hard To Read) Door Tag:
163V-N602-81A-F-64-19500-13?(3or5)-?80?-40 and have need to decipher the both sets of codes. I also need to find an affordable used specification / repair manual to bring it a fully work operational level. I sat in dry storage for over 15 years, so It does need some TLC. I also need to find out who mounted hydraulics for the dump bed and find the maintenance repair information. Any information or a source for same regarding this truck would be deeply appreciated. Please feel free to contact me at:
765/346-1703 or via email: StephenWIrwin@aol.com
"Thank You" for your kind consideration and assistance, Steve Irwin - Martinsville IN
I just purchased a solid "1966 Ford N-300 Dump Truck" VIN# N60CU412339
163 / V / N602 / 81A / F / 64 / 19500 / 135 / 3800 and have need to decipher the both sets of codes.
I also need to find an affordable used specification / repair manual to bring it a fully work operational level. It sat in dry storage for over 15 years, so It does need some TLC. I also need to find out who mounted hydraulics for the dump bed and find the maintenance repair information. Any information or a source for same regarding this truck would be deeply appreciated.
There's no such thing as an N300. The N Series truck (1961/69) could be any of the following: N500 thru N1000.
N60 = N600
C = 292 2V.
U = Louisville KY Assembly Plant.
412339 = 1963, assembled May 1963.
163" Wheelbase.
V = Academy Blue.
N602 = N600, 19,500 lbs. GVWR
81A Standard Cab.
F = Borg Warner T-98 4 Speed Manual Transmission.
64 = Timken Model F106 Single Speed Rear Axle / 6.80-1 / 15,000 lb. Rear Axle Capacity.
19,500 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3800 RPM
Used owners, shop manuals: faxonautolit.com.
Note: Be careful when buying a shop manual. Ford came out with the full shop manual in 1961, then added supplements that covered the years 1962 & 1963.
If you want to learn more about N series trucks, you can go to my web site to the N page.
N_Series_page
N_Series_page
DerekShiekhi
07-25-2016 02:55 PM
DerekShiekhi
1947 and Older Ford Trucks
05-19-2015 10:06 PM
