Why rebuild your 7.3 and for how much? - Ford Truck Enthusiasts Forums
Old 05-10-2010, 02:13 AM
gofalls gofalls is offline
gofalls is starting off with a positive reputation.
I am about to buy a 1993 e350 van with a 7.3 and 400k miles on it. Runs fine now but I imagine it will need to be rebuilt within my ownership of it. How much did you pay for a rebuild and what was the final failure on the motor that made you decide to rebuild?
Old 05-10-2010, 02:42 AM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
no failure yet. got a second engine that i want to get rebuilt and BUILT. quote was 1500-2000 for a basic rebuild.
Old 05-10-2010, 08:28 AM
mechelement's Avatar
mechelement mechelement is offline
mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.
I thought the 7.3L was a bored over 6.9L and the cylinder walls were thinner, thus rendering rebuilds undesirable. I could be completely wrong though.
Old 05-10-2010, 01:22 PM
the 7.3 walls are thinner, but you dont always have to bore over the cylinders when you do a rebuild. only if they are scared up. you can hone the cylinder walls. you can also sleeve the cylinder walls if you want. all depends on the condition of the block,.
Old 05-10-2010, 02:28 PM
BlueOvalBud's Avatar
BlueOvalBud BlueOvalBud is offline
BlueOvalBud is starting off with a positive reputation.
Welcome to the IDI diesel forum!
The 6.9 IDI and 7.3 IDI are very similar and most external parts can be swapped between the two.
Find an '86 or '87 6.9 engine. Have the 6.9 rebuilt and install that into your truck.
Why? The 7.3 is a bored out 6.9, so the 7.3 cylinder walls are thinner. The 7.3's are prone to cavitation (when the cylinder walls develop pin holes and leak coolant into the cylinder). Don't bother with a rebuilt 7.3 because the cylinders are sleeved. Dave S. went through 3 rebuilt 7.3's where the sleeves were incorrectly installed. Finally, he built a 6.9 and is doing well. Oh, by the way, his 6.9 is far from stock and holds up excellent.
I don't have a ballpark number for a rebuild. However, members spend about 5,000 if the machine shop does the machining and you do the assembly.
Old 05-10-2010, 08:02 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Mileage doesn't really mean anything...... If it was properlly maintained, it can go another 300k miles as long as you keep it up.
Old 05-10-2010, 10:02 PM
You bring up a good point about the mileage! Maintenance is key!
Old 05-10-2010, 10:52 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
id do a compression test,and see if it burns oil.if both are tolerable,id grab a new ip,set of injectors,have it professionally timed,and run her.
if it fails inside 100k mile,your not out anything.put the ip/injectors on the new(er)/rebuild and keep going.
cavitation check already mentioned.
difficulty of a total rebuild fscarrow 1999 - 2003 7.3L Power Stroke Diesel 24 08-10-2014 10:30 PM
Introduction/About you thread, 20 simple questions. BlueOvalDismantlers 1973 - 1979 F-100 & Larger F-Series Trucks 46 10-15-2012 08:43 PM
How to: Fuel Bowl Rebuild (Video) A/Ox4 1999 - 2003 7.3L Power Stroke Diesel 22 03-07-2012 01:48 AM
"The 48 Rules of Power" (have you heard of this?) Greywolf General NON-Automotive Conversation 11 10-13-2010 07:38 PM
7.3 engine manual 96 Rex Lewellen 1994.5 - 1997 7.3L Power Stroke Diesel 3 12-01-2008 03:35 AM
Tags
69, 70, 73, 73l, bore, dana, diesel, ford, idi, liter, overhaul, powerstroke, rebuild, rebuilding, rebuilt, reviews
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
