Rockwell Build Thread - Page 49 - Ford Truck Enthusiasts Forums
  #721
Old 05-22-2012, 11:22 AM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
You sure as hell could steer better without the front welded. Even something like a Detroit will ratchet a little when not under full pedal.
  #722
Old 05-22-2012, 11:40 AM
Kirbys73F100's Avatar
Kirbys73F100 Kirbys73F100 is offline
Kirbys73F100 is gaining momentum as a positive member of FTE.
Quote:
I know it and completely agree. I'm trying to get ready for an event in the mountains and money is short so I'll having to prioritize spending. Grizzly lockers went up to $450 and the life time warranty is $50 extra. I'm sure as hell not going hill climbing with an open front diff.. And I think the welded spiders are stronger than any locker. I still have a cage to build before June 16. Gotta give me some credit for doing the twin stick, especially for free.
  #723
Old 05-22-2012, 02:57 PM
I understand not having a locker in your budget and i agree a properly welded carrier should be as strong as a spool/locker. I do not agree that welding the front carrier was the best idea for a truck that is built for trails.
Twinstick is free to most everyone with half a brain.
Pull t-case -$0
Grind rails - $0 unless you dont have a die grinder and burr
Spare stock shifter - $0 for most people with a small supply of spare parts.
Couple pieces of scrap tube, flat bar and 2 bolts/nuts/washers - $0 for anyone who welds and turns wrenches just a little bit. $5 at most if you had to buy a couple 3' sticks from the metal rack and a couple 1/4" bolts from Lowes.
Reinstall t-case - $0
Did i forget something that adds great expense to this?
  #724
Old 05-22-2012, 10:45 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
Funny thing about welded front axles, even in two wheel drive you can break axle shafts/u joints just by turning the steering wheel. (I've done it)
Free twin sick, good for you
  #725
Old 05-22-2012, 11:33 PM
Quote:
Originally Posted by hav24wheel View Post
I don't care what it's in, a welded steer axle is plain stupid.
And you don't have rockwells.
  #726
Old 05-23-2012, 09:20 AM
hav24wheel's Avatar
Quote:
Yes, you are right. BUT I know people that do/did, and they where breaking front shafts with open diffs.
  #727
Old 05-23-2012, 12:25 PM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
Sounds like it's a PITA, but I've heard of people unlocking one side of welded steer axles until they need the extra traction. Puts more strain on the side they stays locked too, but probably not too much of a problem with rockwells..
  #728
Old 05-23-2012, 12:30 PM
Thank God.
  #729
Old 05-23-2012, 02:48 PM
77mud's Avatar
77mud 77mud is online now
77mud has a good reputation on FTE.77mud has a good reputation on FTE.77mud has a good reputation on FTE.
Quote:
Any throttle and its gonna yank the wheel outta your hand.....
  #730
Old 05-23-2012, 03:09 PM
Well maybe if you have little girl hands...
  #731
Old 05-23-2012, 06:22 PM
hav24wheel's Avatar
That's a **** poor idea too.
Doesn't work worth a ****. Pulls to one side, any bit of articulation that pull wt off the locked in tire and it spins.
Plus highly doughtfull that he has lockouts on his axle.
  #732
Old 05-23-2012, 11:14 PM
captain p4's Avatar
I said it was a pita, but it does help you steer.
  #733
Old 05-23-2012, 11:20 PM
No steering wheel feed back with full hydro and I wish I had lockouts.
  #734
Old 05-23-2012, 11:25 PM
73 ford guy's Avatar
73 ford guy 73 ford guy is offline
73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.
Case of Coors lite or Bud lite Lime! Lol
  #735
Old 05-23-2012, 11:36 PM
Screw the rockwells! With the extra weight your adding,more effort is needed to make the truck go compared to lighter 1 tons done right getting it done.
I'd build steering 14 bolts or a Jana76 over rockwells anyday!
I think Tim Cameron knows what works in link below
http://www.pirate4x4.com/feature/cameron-2011/index.php
I'm buying a 2.5 ton Rockwell tomorrow! Kirbys73F100 Offroad & 4x4 102 11-17-2014 10:41 PM
4x4 600 crew build Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 12 03-14-2014 08:37 PM
600 4x4 crew build Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-22-2014 05:16 PM
600 4x4 build thread Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-22-2014 05:16 PM
'79 F250 on Rockwells/53's Kirbys73F100 1973 - 1979 F-100 & Larger F-Series Trucks 32 03-29-2011 11:49 PM
Tags
1988, bolts, build, built, ford, home, making, mud, page, rockwell, rockwells, thread, ton, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
