Rockwell Build Thread - Page 47 - Ford Truck Enthusiasts Forums
  #691
Old 01-26-2012, 11:09 PM
73 ford guy's Avatar
73 ford guy 73 ford guy is offline
73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.
  #692
Old 01-26-2012, 11:14 PM
  #693
Old 01-26-2012, 11:16 PM
thekingofcows's Avatar
thekingofcows thekingofcows is offline
thekingofcows is gaining momentum as a positive member of FTE.
Wow. Evidently they had not done there research.
  #694
These are Thomas and Bettes though... kinda higher.
  #695
Old 01-27-2012, 07:03 AM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
I've ran batteries in parallel with no isolator for years without a issue. And guess what. Semis have been doing it for even longer. Isolaters are for people that know not what they are doing and like to spend $
Also. Just replace ur traction bar shackle with some rod ends and you will be good to go. I had 0 binding issues with mine.
  #696
Old 01-27-2012, 08:00 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
yup. diesel pickups have been running parallel batteries for close to 30 years without any problems as long as the batteries are the same size.
  #697
Old 01-27-2012, 08:50 AM
Yeah if they are the same battery as u said.
It sure is nice to have a switch though if one goes dead
  #698
Old 01-30-2012, 05:44 PM
Kirbys73F100's Avatar
Kirbys73F100 Kirbys73F100 is offline
Kirbys73F100 is gaining momentum as a positive member of FTE.
Testing out the front hitch
  #699
Old 02-10-2012, 12:33 AM
My new to me tow truck. 97 f350 460 5 speed one owner, 100k miles
  #700
Old 02-10-2012, 12:38 AM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
i like it, but it needs a self righting jib crane
hey, tow rigs flop too.
  #701
Old 02-10-2012, 07:50 AM
hav24wheel's Avatar
U know, I'm not all that impressed with stock 460s.....
I think a stock 360 has more get up n go.
  #702
Old 02-10-2012, 12:41 PM
yeah, i bet your stock smog era 460 is a pig but...
97 would be 275ish hp and 400ish ft-lbs stock. highest output for the efi 460's but they down played the numbers because it was the same output as the v10 that was about to replace it. only had 1 fe motor ( pretty stock 390) but my efi 460 would have walked all over that thing easy. it'll move anything you want, hell mine still did on 38's with 3.55's, but don't ever expect to get more than 6-7mpg's hauling anything.
  #703
Old 03-21-2012, 12:43 AM
Did some r&d with the trucks today:
1987 F150
1979 F250
And we found the flex limit on the four linked truck:
  #704
Old 03-21-2012, 04:05 PM
77mud's Avatar
77mud 77mud is online now
77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.
looks like it need the self righting jib crane
  #705
Old 03-29-2012, 11:43 PM
Quote:
That's what winches are for...
That ^ ... and as a frame lift.
Finally found time to work on the truck some. I took 4 leaves from each side of the the rear suspension which took it back to the standard 8" Superduty leaf pack but I wasn't happy with it still. I ended up removing one more from each side. I was satisfied with the outcome but lost a good bit of lift obviously. I bought longer shackles and got er back level. It rides a lot better too. I picked up the front end too which flexed the rear suspension more but I didn't get pictures of that.
I found a 4 core F350 radiator for cheap that I'm gonna pick up Saturday. Hopefully I'll have time to install that, the electric fan and the dual pulley power steering setup I got from an E350 motor home a while back.
Air ride conversion for F700, tell me about Rockwell axles. telescope-tech Large Truck 5 03-19-2017 03:30 PM
I'm buying a 2.5 ton Rockwell tomorrow! Kirbys73F100 Offroad & 4x4 102 11-17-2014 09:41 PM
1975 F-600 4x4 Incident Command truck mount_vernon_mike Large Truck 8 09-18-2013 07:46 PM
'79 F250 on Rockwells/53's Kirbys73F100 1973 - 1979 F-100 & Larger F-Series Trucks 32 03-29-2011 10:49 PM
66 inch tires Ds7776 General Automotive Discussion 3 11-03-2009 08:51 PM
Tags
1988, bolts, build, built, ford, home, making, mud, page, rockwell, rockwells, thread, ton, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
