Offroad & 4x4
Rockwell Build Thread
Old 08-15-2011, 10:07 PM
Kirbys73F100's Avatar
Kirbys73F100
Kirbys73F100 is offline
Originally Posted by 73 ford guy
But seriously you could always just run the winch line on a tree branch power the thing up then roll it flat and drop it in the hitch. Or even better yet mount a ****** block/ pulley on top of winch near top center so it picks itself up flat for easier install.. Just an idea
ORRRR... I could be a man, pick the **** up, slide that long shaft in the slot and be done with it!
  #632
Old 08-15-2011, 10:53 PM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
Originally Posted by alpha/omega
Isnt half (if not 90%+) the point of building a removable hitch mounted winch is REMOVING IT? This ******* is going to weigh 250-300lbs if not more. Its not the issue of 2 guys picking up that much weight roughly waist high...its maneuvering that little 2" square tube into a 2" square socket while holding 300lbs waist high.
I'm agreeing with this and it's not about to show how tough you are when you throw your back out lifting this thing. We have a saying at work as a steel worker, steel installer.. You can work hard or work smarter. I'd use the winch to lift itself kinda a no brainer and now it can be a one person job
  #633
Old 08-16-2011, 02:01 AM
fatdan460's Avatar
fatdan460
fatdan460 is offline
Originally Posted by Kirbys73F100
ORRRR... I could be a man, pick the thing up, slide that long shaft in the slot and be done with it!
this could be edited into so much gayness to represent what travis really meant, but i'm ok with his manlovin' ways, so i will let it be.
those 4 stars queer it up bad..,
15k is a dumb amount of weight to try and multi mopunt pull, yeah i know you built your own, but no, dumb and waiting for it to go ka bang.
i have to agree with shiny cop glasses mcgee. double reciever mounts will make it more stable in general for the sideloads all winches deal with, stronger cause duh, twice as much mount=twice-ish the strength.
you're just going to end up with a lot of bent frames amd broken mounts, if not some winches flying at the truck it's trying to pull.
just for gits and shiggles go get stupid burried and have one of these 5 trucks tether to a solid point and winch you a few times to test it and see if some doesmn't go wrong.it may not, either way get pics and come back with the results.
  #634
Old 08-21-2011, 01:05 AM
Kirbys73F100
Almost finished the rear bumper. Just needs paint now. Maybe some d rings
  #635
Old 08-21-2011, 01:10 AM
fatdan460's Avatar
fatdan460
travis that's a nice looking bumper, but it doesn't seem to fit the truck or follow the lines at all. to be honest why bother with a bumper? i'd have just went with a receiver mount back there tied into the frame really damn good.
p.s. is that a ball of aluminium foil in the hitch hole?
  #636
Old 08-21-2011, 09:24 AM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
That's it!
No OD green paint for George.
  #637
Old 11-25-2011, 11:38 AM
Kirbys73F100
Merry Christmas to me!
  #638
Old 11-25-2011, 12:12 PM
73 ford guy
That front shackle is rediculous overkill!
  #639
Old 11-25-2011, 12:51 PM
73 ford guy
Tires are sick though. What are they 46's?
  #640
Old 11-25-2011, 04:24 PM
Kirbys73F100
46x19.5x15.
Now, what's wrong with the front shackles?
  #641
Old 11-25-2011, 07:24 PM
fatdan460's Avatar
fatdan460
46x19.5x15.
pretty sure he's talking about your redonkulous d ring shackle
had it out to play with the new meats yet?
  #642
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,102 Likes on 2,164 Posts
shackle. singular.
the big stupid looking thing hanging off the front you use to hook little chains to to pull you out when you get stuck.
  #643
Old 11-25-2011, 07:36 PM
Kirbys73F100
Originally Posted by tjc transport
shackle. singular.
Gotchya, never heard it called that before now. Must be a yankee thing.. But it's for show only, way to heavy to actually use. Wouldn't hook it there anyways. Badass d ring though.
  #644
Old 11-25-2011, 07:41 PM
Kirbys73F100
Messed around a little in the pasture. Hearing is obviously much better, rides like it did on 44s and makes a butt ton more power.
  #645
Old 11-25-2011, 07:44 PM
tjc transport
i ain't rite
we use them on cranes for lifting very heavy things where you need multiple cables, like large underground concrete structures used in sewers.
Quick Reply: Rockwell Build Thread
