Rockwell Build Thread - Page 43 - Ford Truck Enthusiasts Forums
  #631
Old 08-15-2011, 11:07 PM
Kirbys73F100's Avatar
Kirbys73F100 Kirbys73F100 is offline
Kirbys73F100 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 73 ford guy View Post
But seriously you could always just run the winch line on a tree branch power the thing up then roll it flat and drop it in the hitch. Or even better yet mount a ****** block/ pulley on top of winch near top center so it picks itself up flat for easier install.. Just an idea
ORRRR... I could be a man, pick the **** up, slide that long shaft in the slot and be done with it!
  #632
Old 08-15-2011, 11:53 PM
73 ford guy's Avatar
73 ford guy 73 ford guy is offline
73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.
Quote:
Originally Posted by alpha/omega View Post
Isnt half (if not 90%+) the point of building a removable hitch mounted winch is REMOVING IT? This ******* is going to weigh 250-300lbs if not more. Its not the issue of 2 guys picking up that much weight roughly waist high...its maneuvering that little 2" square tube into a 2" square socket while holding 300lbs waist high.
I'm agreeing with this and it's not about to show how tough you are when you throw your back out lifting this thing. We have a saying at work as a steel worker, steel installer.. You can work hard or work smarter. I'd use the winch to lift itself kinda a no brainer and now it can be a one person job
  #633
Old 08-16-2011, 03:01 AM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
Quote:
Originally Posted by Kirbys73F100 View Post
ORRRR... I could be a man, pick the thing up, slide that long shaft in the slot and be done with it!
this could be edited into so much gayness to represent what travis really meant, but i'm ok with his manlovin' ways, so i will let it be.
those 4 stars queer it up bad..,
15k is a dumb amount of weight to try and multi mopunt pull, yeah i know you built your own, but no, dumb and waiting for it to go ka bang.
i have to agree with shiny cop glasses mcgee. double reciever mounts will make it more stable in general for the sideloads all winches deal with, stronger cause duh, twice as much mount=twice-ish the strength.
you're just going to end up with a lot of bent frames amd broken mounts, if not some winches flying at the truck it's trying to pull.
just for gits and shiggles go get stupid burried and have one of these 5 trucks tether to a solid point and winch you a few times to test it and see if some doesmn't go wrong.it may not, either way get pics and come back with the results.
  #634
Old 08-21-2011, 02:05 AM
Almost finished the rear bumper. Just needs paint now. Maybe some d rings
  #635
Old 08-21-2011, 02:10 AM
travis that's a nice looking bumper, but it doesn't seem to fit the truck or follow the lines at all. to be honest why bother with a bumper? i'd have just went with a receiver mount back there tied into the frame really damn good.
p.s. is that a ball of aluminium foil in the hitch hole?
  #636
Old 08-21-2011, 10:24 AM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
That's it!
No OD green paint for George.
  #637
Old 11-25-2011, 12:38 PM
Merry Christmas to me!
  #638
Old 11-25-2011, 01:12 PM
That front shackle is rediculous overkill!
  #639
Old 11-25-2011, 01:51 PM
Tires are sick though. What are they 46's?
  #640
Old 11-25-2011, 05:24 PM
46x19.5x15.
Now, what's wrong with the front shackles?
  #641
Old 11-25-2011, 08:24 PM
46x19.5x15.
pretty sure he's talking about your redonkulous d ring shackle
had it out to play with the new meats yet?
  #642
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
shackle. singular.
the big stupid looking thing hanging off the front you use to hook little chains to to pull you out when you get stuck.
  #643
Old 11-25-2011, 08:36 PM
Quote:
Originally Posted by tjc transport View Post
shackle. singular.
Gotchya, never heard it called that before now. Must be a yankee thing.. But it's for show only, way to heavy to actually use. Wouldn't hook it there anyways. Badass d ring though.
  #644
Old 11-25-2011, 08:41 PM
Messed around a little in the pasture. Hearing is obviously much better, rides like it did on 44s and makes a butt ton more power.
  #645
Old 11-25-2011, 08:44 PM
i ain't rite
we use them on cranes for lifting very heavy things where you need multiple cables, like large underground concrete structures used in sewers.
I'm buying a 2.5 ton Rockwell tomorrow! Kirbys73F100 Offroad & 4x4 102 11-17-2014 10:41 PM
4x4 600 crew build Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 12 03-14-2014 08:37 PM
600 4x4 crew build Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-22-2014 05:16 PM
600 4x4 build thread Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-22-2014 05:16 PM
'79 F250 on Rockwells/53's Kirbys73F100 1973 - 1979 F-100 & Larger F-Series Trucks 32 03-29-2011 11:49 PM
Tags
1988, bolts, build, built, ford, home, making, mud, page, rockwell, rockwells, thread, ton, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
