Rockwell Build Thread - Page 41 - Ford Truck Enthusiasts Forums
  #601
Old 08-15-2011, 11:10 AM
Kirbys73F100's Avatar
Kirbys73F100 Kirbys73F100 is offline
Kirbys73F100 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by hav24wheel View Post
I think you better have a heavier tube on that thing. Solid stock or might as well leave it at home.
Also, the receivers better have some crazy beef to them.
  #602
Old 08-15-2011, 11:26 AM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
That looks like 1/4" square tube with a piece of 1/4 2x2 plate welded to the end with a 1" drain hole.
...as mentioned earlier.
Id pull my left nut out of socket trying to move the winch mount, winch and on board battery.
...also, as mentioned earlier.
  #603
Old 08-15-2011, 11:32 AM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
Its still not solid stock......
I made a front receiverhitch out of 3/8ths 2.5x2.5 square for the frame to frame part, and its got a good bend to it now.. And that's just from tugs on a strap.
  #604
Old 08-15-2011, 11:44 AM
Haha. You can't move this thing with a battery sitting on it. Once again though, we've built something that ya'll would have built differently. We'll just have to see how out works.
I have decided on new tires though. I want a set of 44" boggers and a set of 46" ags. After I get the front bumper built, I'm gonna start on a set of rockwell 15's unless I can find a used set for cheap.
  #605
Old 08-15-2011, 11:49 AM
hav24wheel's Avatar
If you had a smaller winch on it I wouldn't see a problem. But that's a hell of a lot of pulling power.
New tire choices are good imo
  #606
Old 08-15-2011, 11:51 AM
Figured I needed a big winch for a big truck...
  #607
Old 08-15-2011, 11:52 AM
Isnt half (if not 90%+) the point of building a removable hitch mounted winch is REMOVING IT? This ******* is going to weigh 250-300lbs if not more. Its not the issue of 2 guys picking up that much weight roughly waist high...its maneuvering that little 2" square tube into a 2" square socket while holding 300lbs waist high.
Im diggin' the tire choices also
  #608
Old 08-15-2011, 11:59 AM
Its not that bad, we lifted it in and out several times yesterday. How would you make a 160 pounds winch removable?
  #609
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
kirby, i'd skip boggers all together if i was you, but i assume they will be your "street tires" :shakeshead:
just go ags and don't look back. cheaper that way.
  #610
Old 08-15-2011, 12:01 PM
Id buy 2 and keep my schnuts in their socket where they belong. I probably couldnt move the winch alone if it were sitting on the ground...much less the mount and battery as a unit.
Or Id build a bed mounted jib crane with a boom long enough to reach the front and rear bumper as well as my buddys truck if he parked close enough.
  #611
Old 08-15-2011, 12:05 PM
i was expecting no less when i saw "how would you move it?"
  #612
Old 08-15-2011, 12:08 PM
ags don't flex so well on the rocks DAN. I already went the cheap route and we all know how that went.
  #613
Old 08-15-2011, 12:11 PM
if you want to play on rocks go with 47" LTBs, 44" Rockers or 42" SXs. Boggers have no lateral traction on rocks.
  #614
Don't be a sissy alpha.. I'm not gonna buy two 1800 dollar winches because you're not man enough to lift 200 pounds waist high.
  #615
Old 08-15-2011, 12:15 PM
Dan
Photoshop
GO!.....
I'm buying a 2.5 ton Rockwell tomorrow! Kirbys73F100 Offroad & 4x4 102 11-17-2014 10:41 PM
4x4 600 crew build Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 12 03-14-2014 08:37 PM
600 4x4 crew build Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-22-2014 05:16 PM
600 4x4 build thread Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-22-2014 05:16 PM
'79 F250 on Rockwells/53's Kirbys73F100 1973 - 1979 F-100 & Larger F-Series Trucks 32 03-29-2011 11:49 PM
Tags
1988, bolts, build, built, ford, home, making, mud, page, rockwell, rockwells, thread, ton, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
