Offroad & 4x4
Rockwell Build Thread
Old 07-13-2011, 11:58 AM
fatdan460's Avatar
fatdan460
fatdan460 is offline
nice! it's always fun to be the big truck...........until you get stuck, and then you are generally screwed.
  #572
Old 07-13-2011, 12:15 PM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
I can't believe 2 , 12,000 lb winches couldn't get you unstuck!!
Mind you the suction to break those tires free would be a bitch.
Did you guys run double line pulls on the winches with the back end of the recovery trucks anchored to a tree? That would make 48,000 lbs of pulling power!!
  #573
Old 07-13-2011, 12:25 PM
fatdan460's Avatar
fatdan460
getting buried that deep is hell on anything to try and move. last time i was that stuck it took 2 semi wreckers to get me out, technically only the one pulling, but they anchored the trucks together and had to run line to a telephone pole and their 30k single line still took over an hour to move me 25 feet to freedom. the suction was so bad that my frame was flexing when i tried to gas it to help them out, bed rubbed the hell out of the cab.
  #574
Old 07-13-2011, 12:30 PM
Kirbys73F100's Avatar
Kirbys73F100
Kirbys73F100 is offline
We tied both trucks off to trees and both had two ****** blocks. The trees started coming out of the ground. The bronco you see in the picture wasn't touching the ground anymore.
  #575
Old 07-13-2011, 12:38 PM
captain p4's Avatar
captain p4
captain p4 is offline
Got damn, nice work Kirbers
  #576
Old 07-13-2011, 01:15 PM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
Not too bad.
+1 for welding your rear carrier.
  #577
Old 07-13-2011, 01:18 PM
fatdan460's Avatar
fatdan460
i think his rear is welded. kirby, you go full hydro steering? weld em both up.
  #578
alpha/omega
Originally Posted by Kirbys73F100
At one point the bell housing bolts backed out and the transmission became detached from the motor, pulling the driveshaft from the slip yoke.
This trumps all other automotive fails that you have posted. Good job, or better yet...tighten your freakin' bolts.
  #579
Old 07-13-2011, 01:22 PM
alpha/omega
There is no way THIS rear end is welded unless he is absent the ability to spin those tires much over idle
  #580
Old 07-13-2011, 01:30 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
Rockwells are super easy to weld too. I weldednone for a friend with my 110lincoln and it still holding up. Even broke a couple shafts. Lol.
X2 on tightining the bolts. I'ive been accused of over tighteningnthings but I haven't had onecome loose.
  #581
Old 07-13-2011, 02:18 PM
Kirbys73F100
Thanks!
I'm saving for a Grizzly locker for the front
Oh damn! That's a great idea. Thanks for that advice. I'll go do that right now.
THAT rear end is welded.
  #582
Old 07-13-2011, 03:15 PM
alpha/omega
Then am I missing something or did your passenger side rear tire not spin at all when your front went under?
  #583
Old 07-13-2011, 08:54 PM
Kirbys73F100
That's a picture of it getting pulled out. At one point all four were out of sight.
This is just after we started pulling it. It refused to come up and out and just got deeper from there.
  #584
Old 07-13-2011, 08:56 PM
alpha/omega
wheres the pic of that?
  #585
Old 07-13-2011, 11:05 PM
lucky_thirteen's Avatar
lucky_thirteen
lucky_thirteen is offline
What a turd
Quick Reply: Rockwell Build Thread
