Rockwell Build Thread - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 05-12-2010, 01:10 AM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
good platform? any leaf sprung ford ever made is a candidate for a simple swap. or anything that you can fit leaf springs under. my vote goes to a ford festiva on a shortened bronco II frame with a 460 rammed into it
  #32
Old 05-12-2010, 01:33 AM
Prozon's Avatar
Prozon Prozon is offline
Prozon has a good reputation on FTE.Prozon has a good reputation on FTE.
Ah but hell Dan, lets take this over to the other thread so I don't upset Kirby by hijacking his thread. Hadn't intended to.
http://www.ford-trucks.com/forums/91...erish-130.html
My reply is over there.
  #33
Old 05-12-2010, 07:20 AM
TheTinian's Avatar
TheTinian TheTinian is offline
TheTinian is gaining momentum as a positive member of FTE.TheTinian is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Prozon View Post
Oh and Tinian, still want those rocks? Haha. Sadly they're not selling.
Sure. I'll take em off your hands.
  #34
Old 05-13-2010, 09:01 AM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
Quote:
YouTube - Dumb and Dumber
  #35
Old 05-13-2010, 02:58 PM
Prozon's Avatar
Hows the progress on this thing?
  #36
Old 05-13-2010, 03:25 PM
kirby, is this a relative of yours?
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/C9D0UjGaTIs&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/C9D0UjGaTIs&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********>
  #37
Old 05-13-2010, 03:35 PM
TheTinian's Avatar
DAMN!
Thats how I mount all my tires.
I've never had that happen. I do em on the ground and with the 44's they lifted a couple feet off the ground when they popped.
  #38
Old 05-13-2010, 03:39 PM
there's one vid with a guy mounting 44's on 21'' wide wheels. retarded. i have mounted tires like that too, except the spray can torch to light it. i try to stand back and throw a match or something.
  #39
Old 05-13-2010, 03:55 PM
TheTinian's Avatar
I do the spray torch thing....
Or you run the rim with brake cleaner and continue it on the ground to make a trail so your not too close.
Usually have 3 people to do it. One to spray, one to light, and one with water if it doesn't seat.
Call me a retard......
  #40
Old 05-13-2010, 04:44 PM
Prozon's Avatar
Quote:
Okay! RETARD.
Not sure why though. Good method, i've heard of tires getting burned up. Always good to have somebody nearby with water haha.
  #41
Old 05-13-2010, 05:36 PM
Karl, Nick #2 and myself did that to my boggers and Ive done several tires this way before and since. Easy if youve got good sense and are careful.
  #42
Old 05-13-2010, 07:13 PM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
^trufcakes.
Just don't over do it on the fuel source.
  #43
Old 05-19-2010, 03:08 PM
greenwoodford's Avatar
greenwoodford greenwoodford is offline
greenwoodford is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Kirbys73F100 View Post
If I have too much of a problem, I'll trade my brand new 53s for a bogger in a smaller size. There's a lot of weight to be saved by running a normal offroad tire/wheel.
I am by no means a tire or off-road expert, but I am not a fan of the 53's. They are a VERY strong tire (we have 100,000 lb. trucks using them), but they do not fare well in the mud. Maybe it's the excessive weight of the trucks or maybe it's the nasty mud over here in Iraq; or it might be both. Even when the tires are spinning pretty fast (fast enough to clean out boggers) the treds still stay caked in mud.
This is a picture of my 40,000lb. MRAP a few weeks ago after it rained the night before. Even after we got back to our fob and had been riding at 60mph the tires were still full of mud. Again, I'm not an expert; just giving my opinion and experience. Good luck on the build.
  #44
Old 05-19-2010, 03:18 PM
Prozon's Avatar
Looks like the military could use some boggers.
*gasp*
A military strength bogger?
  #45
Old 05-19-2010, 03:21 PM
i saw a video on youtube about industrial iroks, so you never know. but i doubt they would go for it. but a hemtt on 54'' boggers would be about as cool as anything could ever be
I'm buying a 2.5 ton Rockwell tomorrow! Kirbys73F100 Offroad & 4x4 102 11-17-2014 10:41 PM
4x4 600 crew build Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 12 03-14-2014 08:37 PM
600 4x4 crew build Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-22-2014 05:16 PM
600 4x4 build thread Bobird 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-22-2014 05:16 PM
what brake system to use rockwell 5 ton 78_f800crewcab4x4 Offroad & 4x4 38 11-10-2013 06:42 PM
Tags
1988, bolts, build, built, ford, home, making, mud, page, rockwell, rockwells, thread, ton, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
