Great and Cheap rust remover, not Syrup
#31
I checked out our local food store and they had white vinegar in two strengths. Regular was 5% acidity and extra strength which was 9% acidity. I got a gal. of each and will give them a try. I know that when I worked in the environmental field, we were call out to the Pace plant (maker of Pace Pecante Sauce) to clean up a spill of high strength vinegar, it had eaten up the asphalt parking lot. After the clean up we had to cut out the asphalt and repave the area covered by the spill. I'm sure they used a higher strength vinegar than is avail. to normal consumers. Some powerful stuff.
Gil
Gil
#32
#33
#34
So the question that comes to my mind is: How come I haven't heard of this before?
So far as the gell question goes. Try mixing in some gelatin. You can buy it in the same isle they have the vinegar. Might work, might not, but don't know.
Another possible idea: soak down the area and lay a garbage bag over it. That will help hold on the vinegar, and prevent it from evaporating.
#35
I'm interested to hear how the gell worked out. That'd make treating the Merc easier.
-James
#36
Received 4,119 Likes
on
#38
on
#40
f1 you have no idea how crazy .... i had 'em all geussing this winter . 6 inches on the ground , below zero and wearing tennis shoes , cut off jeans , and a sleeveless flannel ............. i may have too try this on some stuff i got around here and see how well it works ............. good thing is as someone mentioned i think , as long as it hasn't got paint or other automotive chemicals in it it's biodegradeable ..................... have to keep mallethead away though as that silly **** would prolly eat it ...............
#43
#44
#45
I've been using regular vinigar in a spray bottle, applyed it to my frame and cross members and you could see the rust running down. I happened to let it dry over night (because it got too late). Next day I wire brushed ( cupped brush on grinder) The result was remarkable, it all came out shiney metal. Even the old paint was gone.
And to think my wife said to do this cuz she read it on a helpful hints for the home place.
